Won't Rev past 2250rpm after plenum spacer /stillen intake
Old Dec 29, 2013 | 10:46 PM
Speedster's Avatar
Man, no clue what is going on but I just finished installing a motordyne iso thermal plenum spacer and stillen airbox and z tube. No obvious vacuum leaks that I see or hear. I did unplug the battery before I started, and tapped the brakes for a ecu reset before connecting the battery after install.
The first couple miles it was running fine then all of a sudden it won't Rev past 2250rpm. It's almost like it hits and starts bouncing off a Rev limiter. Here is a short video I made :
What could be causing this,has to be something I'm missing. Should I try an ecu reset the pedal method? It would have to be an ecu issue since in any gear it won't rev pst the exact same rpm?
Car is a 2003.5 sedan 5at
Old Dec 29, 2013 | 11:14 PM
Pepper's Avatar
G35 sedan won't accelerate past 2250rpm - YouTube
https://g35driver.com/forums/engine-...resetting.html
Daniel k.
Nov 3, 2015 09:52 AM
03sedang35
Aug 29, 2015 07:56 PM
cbax
Aug 17, 2015 07:41 AM
Raven7
Aug 14, 2015 04:40 PM
