time for a tune up?
Old Apr 14, 2014 | 11:28 AM
Peoria35sedan's Avatar
There's a sticker in the drivers side door jamb that has the production date.
You may need to replace some front end bushings, compression rods tend to fail well before 100k.
Old Apr 14, 2014 | 11:47 AM
nismo714's Avatar
Awesome thank you!
Old Apr 14, 2014 | 12:55 PM
Mustang5L5's Avatar
Originally Posted by Stillen06coupe
Nology silver plugs are actually the best plugs out there because silver is the best thermal and electrical conductor of ALL metals. Problem is, not sure how often they need replaced. Cuz we all know changing plugs on a VQ isn't a walk in the park
Too soon. I've used them before (on a different car) and they wear pretty quickly. Really wouldn't recommend those on anything buy a low-miles-per-year toy.
Silver and copper plugs are great conductors, but wear fast. Back when copper plugs were the norm, you'd change them out every 20K miles. I still run coppers on my Mustang because the primitive fuel injection and ignition system doesn't handle platniums well. Thanksfully, it's a 15 min job.
Old Apr 14, 2014 | 01:01 PM
coffeysm's Avatar
Well, my car is all fixed now and rides smooth at all speeds, lol. I did fix a lot of things at once though.
I would make sure it's balanced, aligned, and none of the wheels are bent. Try jacking up each side and grab each tire push up, down, and side to side. See if you have any play at all.
Old Apr 16, 2014 | 09:37 AM
vipster's Avatar
Quick question, I was going to buy the NGK Iridiums but I bought the NGK Laser Double Platinums. I haven't installed them yet as I am waiting to purchase the Motordyne 5/16" Plenum spacer and install the Maxima valve covers I just bought as well. Should I stick with the Laser Dbl Plats or go to Iridiums? I just want to change them while I'll have easy access to everything.
Old Apr 16, 2014 | 10:00 AM
Mustang5L5's Avatar
What's the part number?
I believe they are the OEM plugs if the P/N is PLFR5A-11
Old Apr 16, 2014 | 01:41 PM
vipster's Avatar
This is the plug I bought.
http://www.autozone.com/autozone/par...2663_771127_0_
this is the other NGK plug I didn't buy
http://www.autozone.com/autozone/par...er=937722_0_0_
Old Apr 16, 2014 | 03:37 PM
nismo714's Avatar
So i have the 2belts and set of spark plugs. How much is the labor for replacing these items. Want an idea so i don't get totally robbed.
Old Apr 16, 2014 | 04:06 PM
Mustang5L5's Avatar
That's a stock platnium plug. You can install it. Honestly, you'd prob never notice a difference between stock plugs and iridium.
Couldn't tell you how much to pay. I can tell you it took me about 1 hour to change both on my car. Not a big deal if you have any sort of DIY skills.
Old Apr 16, 2014 | 04:31 PM
TurTLe*'s Avatar
who/where are u going to? Small local shop? bigger chain like firestone/NTB/merlin/carx
Spark plugs i feel is a 1 hour book time job, its not hard nor easy but the plenum stays on so its quick.
Belts are insanely easy to do, book time should be 1/2 to an hour.
So figure most shops want $100/ hour as a average. You should be walking away wit $150-$250 of labor. Maybe have them throw in a oil change and air filter.
Old Apr 17, 2014 | 12:31 PM
nismo714's Avatar
I'm at the shop right now and 2 if the 6 spark plug enclosures has oil leaking into it. Seems like it just needs a new gasket to seal.
The mechanic says that will be an all day job since he has to "take everything apart". Is this true? I was reading up on it and it didn't sound like the case.
I'm not going to get this done today but how much am i looking at for this job?
Old Apr 17, 2014 | 12:37 PM
vipster's Avatar
From what I read you can't replace just the spark plug seals unless you use a hole saw. You could do like I'm gonna do. I bought some 04 maxima valve covers and gaskets and will be changing them out as soon as I buy my Plenum spacer .
I may be wrong but I hear the G's had a bad Rep for leaking into the spark plugs.
Old Apr 17, 2014 | 07:11 PM
5150DS's Avatar
I had the same problem at about 75k. I ignored it and drove it to 120k and did another spark plug change. I had a little oil "sweat", but it was very little. Almost seemed to fix itself . I am at 186k without fixing it and have never had a problem from it. I dont think its a major issue, but ymmv.
Old Apr 17, 2014 | 07:27 PM
coffeysm's Avatar
Yea, the valve covers are known to leak and it's a pretty intensive job. But, there is a design flaw, so it would probably end up leaking again. Plus, I think the parts are like 500-600 bucks alone. Someone recently spent like 100 bucks using Maxima covers I think though and it involved a small mod on one of the hoses to fit properly.
Old Apr 18, 2014 | 12:54 AM
  #30
vipster's Avatar
Yeah I've been doing my research and it seems the #6 cylinder plug needs to be extended a bit to reach properly. I paid about $109 for both valve covers and valve cover gaskets. I'm gonna paint them gold though before I install them.
Good luck with your G. Sorry for thread jacking.
jsimonk
Dec 22, 2023 03:49 PM
poktanG35
Engine - Exhaust
Oct 26, 2015 03:32 AM
Red G Coupe
Tuner & Dyno
Jul 30, 2015 08:32 PM
sick_sixspeed
Jul 20, 2015 10:25 PM
quickspeed6
24
Jul 15, 2015 11:06 AM
