06 g35 brakes on 03 need help!!
Old Aug 2, 2014 | 01:16 PM
GHETTOGRAMMA's Avatar
So I bought 06 brake calipers rotors and pads to put on my 03 sedan got fed up of the soft brakes
So my friends a mechanic and we changed the old ones out put the new ones in everything went well brakes feel great but but everytime I drive hard and use the brakes it keeps smoking I told my friend he said I should put in some ss brake lines
Would that solve the problem??
Old Aug 2, 2014 | 02:14 PM
Urbanengineer's Avatar
Your brake lines are swelling? Check your reservoir and see if you lose fluid when under heavy braking.
Old Aug 3, 2014 | 04:24 PM
I checked fluid seems fine my buddy (mechanic) said the caliper is not releasing fast enough
I'm debating on ss brake lines or oem because I'm in the north (canada) and I drive my g all year round
Any feed back on ss brake lines in winter would be helpful
Old Aug 4, 2014 | 10:58 AM
doubleclutch92's Avatar
Did you lube everything? Did you do a brake bed-in after you installed them?
Old Aug 4, 2014 | 11:40 AM
Jeff92se's Avatar
Red Card Crew
Lines won't make a difference. You need to find out why they aren't releasing if that's the case. When I swapped mine, it was good to go
Old Aug 5, 2014 | 09:19 AM
Bassman's Avatar
Where they used calipers? If so the seals need to be changed. The piston seals deform when the brakes are applied and snap back when released. the seal pulls the brake piston back. Not a hard job. I've had to do this on my old motorcycles when the calipers froze.
Old Aug 5, 2014 | 10:57 AM
danoman32's Avatar
Probably used. Need rebuilt.
Old Aug 5, 2014 | 12:34 PM
Yea we lube everything and bed-in it
They were rebuilt calipers with one year warranty
It seem to stop smoke over the weekend I think we didn't clean to oil off the rotors
Thanks for all the input guys all is good
Old Aug 10, 2014 | 03:00 AM
Hotdawwgman's Avatar
New OEM rotors have a ton of oil on them....
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
kinetek
Aug 3, 2015 04:25 PM
ddietz97
Jul 26, 2015 06:16 PM
laksjd84
Jul 24, 2015 05:12 PM
mushu
Jul 15, 2015 03:55 PM
