155k Recommended Service
Old Aug 27, 2014 | 09:38 PM
Fouad1013's Avatar
Hi I just bought my 04 G35 6-Speed. It has 155k miles on it, and sort of an impulse buy. The car has no service records, all I know about it, is that it drives, shifts and stops fine. But I want to take to a dealership and get it checked out and serviced. Someone already meantioned that i should take it to a Nissan dealership since they charge less. My question is what should i get serviced on the car? I was planning on having change the oil, trans and diff fluids. Is there anything else I should get done on the car while its there? Any help would be greatly appreciated.
Thank You
Old Aug 27, 2014 | 11:31 PM
5150DS's Avatar
Brake fluid, radiator fluid, power steering fluid, spark plugs and air filter.
Old Aug 28, 2014 | 07:05 PM
markc's Avatar
Don't worry, if you take it to the dealer they'll give you a looong list of things to spend your money on.
Old Aug 31, 2014 | 12:00 AM
Jbl_91762's Avatar
Like the helpful posts have been, all fluids should be done and check suspension. What did you pay for car? didnt you at least run carfax?
Old Aug 31, 2014 | 02:55 AM
Fouad1013's Avatar
I ran the Carfax. It was 2 owners no accidents clean title. I payed 5700 for it.
Old Sep 2, 2014 | 11:22 AM
Mustang5L5's Avatar
If *I* purchased a 155K mile car with unknown history, this is what I'd do
Engine oil
air filter
cabin filter
brake fluid
trans fluid
differential fluid
spark plugs
radiator coolant
inspect/replace belts
Old Sep 2, 2014 | 11:35 AM
Lartytiejdke3's Avatar
Holy *** these cars are getting stupid cheap now..
Old Sep 2, 2014 | 09:02 PM
Fouad1013's Avatar
So I haven't taken it to get it serviced yet but today I just noticed that it's burning oil at hi rpm. Nothing at idle but when I Rev it white smoke comes out the tail pipe and smells like oil. Idk what it could be
Old Sep 3, 2014 | 04:20 PM
Mustang5L5's Avatar
Yup.
Kinda depressing when i paid almost $30K for mine
Old Sep 3, 2014 | 05:15 PM
gary c's Avatar
Fouad, members have already listed everything that might need to be serviced. There's no reason to spend the kinda $$ that the Stealerships wants for service. Any qualified mechanic can drain & fill all the fluids, change filters and R&R the plugs. White smoke generally means a blown head gasket! (search white smoke) A compression test might be in order to find out. Good Luck & enjoy the ride...Gary
Old Sep 3, 2014 | 05:20 PM
gary c's Avatar
Originally Posted by Mustang5L5
Yup.
Only if you paid $35K like I did 11 years ago!
Old Sep 3, 2014 | 09:44 PM
Fouad1013's Avatar
so after reading up on the oil problems, I checked my PCV valve, and it was soaked in oil. I think that might be causing my problem. I will replace that tomorrow.
Gary, 5150, jbl and Mustang, thanks for the advice. Ive always wanted to do a couple of diy projects on a car, just never had the chance (my dad never trusted me to do anything car related) so I think I will start tackling those things on my own, starting with that PCV valve and air filters, then probably plugs. I will probably take it to jiffy lube for an oil change, since they do free top-offs. I will probably take it to a mechanic for the rest of the fluids, I havent had someone check the under body for rust or anything (should have done it before I got the car, but I needed to a buy a car that weekend and I felt like it was a good deal)
Old Sep 3, 2014 | 09:50 PM
ScraggleRock's Avatar
Its a sedan tho. The sedans have always been fairly cheap. Throw those miles on it and it makes sense. A low miles 6mt coupe can still get really decent money for how old they are.
Old Sep 4, 2014 | 09:34 AM
Blue Dream's Avatar
I drove ttrank's car solo
Please don't take it to Jiffy Lube.
Old Sep 4, 2014 | 11:01 AM
Texasscout's Avatar
You also need to have all the bushing checked, most are gone by that time. I'll bet the differential mounts are leaking and the compression rod bushing are shot.
