2005-06 Rosewood console trim removal...
Old Nov 8, 2014 | 04:28 PM
skippyG's Avatar
I tried to search this but came up with no definitive answer... There was one good thread regarding a 2007, which is obviously not the same.
Can this console trim be removed? If so, how? And what's underneath it?
Old Nov 8, 2014 | 07:55 PM
TurTLe*'s Avatar
what exactly do you mean.....
the wood trim is a faceplate for the radio. Its not glued, its REAL "solid" wood. Things are bolted to wood trim tho, like the metal shifter, radio, navi unit. Its not like a layer over the aluminum.
Old Nov 9, 2014 | 02:06 AM
skippyG's Avatar
That's what I meant....was it a layer of wood on top of aluminum or silver plastic. I thought that it might be an applique because I can see silver around the CD loading slot....
I wanted to know because I'm close to pulling the trigger on a DD install & I wanted to get my finishes to match up. Guess I'll have to try to Dremel my wood faceplate like I saw one guy do it and hope I don't screw it up! Or replace the wood with aluminium....
Old Nov 9, 2014 | 09:11 AM
TurTLe*'s Avatar
Pretty much your only two options are what you stated. The silver you see is the radio itself, its behind the faceplate.
I have the wood and thought about the same.
You also have a 3rd option that i've done. Vinyl wrapping the whole trim pieces to a carbon fiber, aluminum that looks close to stock or any other color. I tested it with a 3m dinoc and it was decent. But now i actually like the wood.
If you want a quick idea of how the wood is, pull the door handles off, they pop right off and it will show u how thick that wood is.
Old Nov 9, 2014 | 01:07 PM
skippyG's Avatar
Yeah... Vinyl wrap idea has merit, not to mention that it's likely a lot cheaper and easier to match. I know what you mean though - I have the wheat leather & the wood actually looks pretty nice.
I may just try to dremel the wood and if I screw it up, I'll just wrap everything!
Old Nov 9, 2014 | 09:16 PM
markc's Avatar
Don't screw it up! Vinyl wrap and wheat will look cheap IMO.
Old Nov 10, 2014 | 09:27 AM
skippyG's Avatar
Yeah.... I'll have to take my time then. And deal with the silver DD for a while....
Old Nov 10, 2014 | 01:29 PM
TurTLe*'s Avatar
i have STONE interior and i did that CF wrap.
Here i'll throw you a BONE...
My first time playing with this... it came out decent. But there was imprefections, mainly on my install. I pulled it off and I was going to redo in this winter in a piano black but the wood grew on me.
Old Nov 10, 2014 | 02:53 PM
skippyG's Avatar
Wow! Quite the project.
Old Nov 10, 2014 | 03:15 PM
Mustang5L5's Avatar
That CF wrap actually looks pretty sweet.
Why not try and source parts off Ebay? I was searching to replace a trim panel not too long ago and saw AL center console parts for not a bad price. The expensive ones were the Navi panels for obvious reasons
Old Nov 10, 2014 | 03:50 PM
skippyG's Avatar
I've seen some of those Aluminum parts for the 05-06's on Ebay - they looked pretty beat up.
Old Nov 10, 2014 | 03:57 PM
Mustang5L5's Avatar
Hit or miss really. With these cars becoming work more in parts than whole sometimes, you miught be able to find someone parting out a car. Check the classifieds or keep an eye on Ebay for some decent parts.
Old Nov 11, 2014 | 02:44 PM
skippyG's Avatar
True. I've come across some decent stuff.
cpmiller22
Oct 10, 2018 10:54 AM
g.spot
May 9, 2016 10:54 PM
Tmatheso
Dec 13, 2015 03:24 PM
heynow
2nd Gen (V36) Sedan
Oct 28, 2015 05:09 PM
Learned Hand
Oct 1, 2015 09:02 AM
