Z midpipe on 05 Sedan!
Feb 17, 2005 | 12:47 PM
Just got the Z's midpipe installed on my 05 6MT sedan. I was originally thinking coupe midpipe, but I spoke with Z Car Garage here in San Jose about it, and they do a custom fit Z midpipe. After talking to Rob at Z Car (nice guy) about which way to go, I decided to go with the Z midpipe.
Result: AMAZING improvement in the sound of the sedan - much deeper and "throatier" than stock, but not over the top. It definitely passes wife acceptance testing (an issue for me at least), and I can still drive a client around in it, but it sounds a LOT meaner.
By my calculations, a fair bit cheaper than the coupe midpipe to boot.
Thanks to Z Car Garage for steering me to this solution. Highly recommended.
wnpublic
Reply 0
Feb 17, 2005 | 01:02 PM
What is the difference between the Z and Coupe mid-pipes? Pics?
Reply 0
Feb 17, 2005 | 01:11 PM
The only difference would be length cuz it's shorter meaning you would have to use an adapter. Was the midpipe + adapter cheaper than jus coupe midpipe?
Reply 0
Feb 17, 2005 | 01:19 PM
Whole thing installed was less than the $235 cost of the coupe midpipe on mynismo.com. Agreed that the Z midpipe is shorter than the coupe's, some welding surgery was performed to make it the right length. I've not seen the coupe midpipe so it may otherwise be identical, I dunno.
Reply 0
Feb 17, 2005 | 01:20 PM
"The only difference would be length cuz it's shorter meaning you would have to use an adapter. Was the midpipe + adapter cheaper than jus coupe midpipe?"
^^^WHS^^^
That is my understanding....
same only shorter & requires extension.
JMO,
But coupe pipe is still the best choice.
You can get a used coupe pipe for less than $100
Reply 0
Feb 17, 2005 | 01:40 PM
either way then, very useful mod
Reply 0
Feb 17, 2005 | 01:43 PM
Quote: either way then, very useful mod
Agreed...
Can't wait 'till I get mine bolted up
Reply 0
Feb 17, 2005 | 02:10 PM
They're identical except for the fact that the G coupe middy will bolt right in without adding an extention. A 10% mark-up will get it for about $180.00 plus gaskets and about a half hour of your time to do it yourself...JBX
Reply 0
Feb 17, 2005 | 06:08 PM
got any sound clips..
or maybe you can head out to our meet this friday..so we can hear it..
Reply 0
Apr 4, 2005 | 07:51 PM
how much does the adapter cost? i think ill be able to get the z midpipe for free.
Reply 0
Apr 4, 2005 | 11:17 PM
I made some sound clips of my 2003.5 Sedan with the stock midpipe vs. with the coupe midpipe. I also made pics comparing the size of the two. Posted this stuff at https://g35driver.com/forums/g35-sedan-v35-2003-06/47509-finally-got-my-midpipe-highly-recommended.html.
If you can find a used coupe midpipe, it's hard to beat the price. Mine cost me $50. Bolted right up without any hassles.
Reply 0
