03 Alternator Stuck?
Old Feb 22, 2015 | 07:28 PM
yabaguymia's Avatar
I have an 03s, manual fan, auto, rwd, with an alternator that refuses to come out. I have both the plug and terminal nut removed, both mounting bolts removed. The stay bracket is swung out of the way. The alternator itself looks to still be pivoting on the thru-bolt mount but it won't slide down at all. I don't see what I am missing with the FSM. Both bolts are still fully intact as well. Anyone, help please? I don't want to start pounding on it.
Old Feb 23, 2015 | 09:07 AM
Mustang5L5's Avatar
You have to sort of swing and pivot while you try and pry it down with a screwdriver.
The top bolt tends to pinch a bit when you tighten it up, so when you remove the bolt, you need to pry it out of that top pivot bracket.
Old Feb 25, 2015 | 02:22 PM
yabaguymia's Avatar
Well I ended up getting it out. There was a stupid little bracket on the top rear of the alternator (that I couldn't see before) that mounts to some flexible hose. Honestly it looks pretty worthless, but that's what the issue was.
Dallsinghjr1
Sep 17, 2023 11:25 AM
brianuc4
19
Apr 10, 2020 02:12 PM
Thebaws11
Nov 30, 2016 12:54 PM
BradMD_96
Oct 6, 2015 09:31 AM
