Need brake pad recommendations.
Old May 30, 2015 | 02:21 PM
dpark0223's Avatar
Do you a specific store link??
Originally Posted by gary c
Once around the block with OEM pads and your wheels are filthy and they don't last much more than 10K miles!
I use DBA slotted/drilled rotors, they not only look but extend the life of your pads because they run cool and can be turned after 30 to 40K miles. DBAs along with HAWK HPS pads are available from our Marketplace under vendor brakes...Gary
Old Jun 1, 2015 | 09:42 AM
Mustang5L5's Avatar
I'm getting ~60K miles out of OEM pads....and very little dust.
These aren't the same as the 03/04 pads. Those were the ones that prompted the TSB due to premature wear and excessive dust.
Old Jun 1, 2015 | 09:46 AM
Texasscout's Avatar
It depends on the year, 2004 and earlier was dust city, 2005+ was no dust.
Old Jun 1, 2015 | 09:55 AM
Mustang5L5's Avatar
Originally Posted by Texasscout
I tried HPS (Holy Piece of Shiz), I know every body thinks otherwise.
I agree they have great bite
I agree they have no dust
What I hated was NO BITE AT ALL when it's wet AND cold. For about a 1/2 a second it's like you have NO BRAKES, then they bite as normal, but I just couldn't get used to it and went to an OEM type ceramic pad. Yes I followed the "bed in" instruction to the letter.
I'm with you as well. I live where it gets to around 0 degrees for a good chunk of the year and found the Hawk's lacked bite when it was cold. I had to give it a few nice hard stops to get some heat in the brakes and then they worked wonderfully. Same deal when driving on the highway. 1 hour with the cruise control on when it was cold out and then get off the highway and you'd have no brakes for a few seconds. Really hated this and chucked them in the track.
I'm sure if you live where it's warm, or always drive aggressively, this isn't an issue, but for my daily driver's, where I let my g/f (who drive's slow and grandmaish) drive the kid around, Its not acceptable.
I also ran the Akebono ACT's for a while. Performance/dust/noise was like OEM, but these ate my Centric rotors up pretty well.
Old Jun 1, 2015 | 10:05 AM
Mustang5L5's Avatar
Their rotors are sweet, but they are expensive. But it's nice to see a manufacture focus on internal vane design to promote cooling, vs thinking drilling 500 holes cools it better.
Old Jun 1, 2015 | 10:32 AM
dpark0223's Avatar
So now im having second thoughts about the hawk hps. I live in new york city. Do you have a recommendation on brake pads and rotors? I have the 06 x.
Old Jun 1, 2015 | 12:22 PM
Texasscout's Avatar
I would stick with OEM or a aftermarket Ceramic.
Old Jun 1, 2015 | 03:11 PM
Mustang5L5's Avatar
If this is just a daily driven car, no need to overthink things....OEM (for a 2006) pads and Centric premium blank rotors are my recommendation.
KruZZe
Feb 27, 2023 05:04 PM
BradMD_96
Oct 6, 2015 09:31 AM
Gabe83714
Oct 6, 2015 06:40 AM
alinero718
Sep 27, 2015 09:35 PM
