Armstrong Compression Rod Bushings Suck
Old Nov 8, 2015 | 07:38 PM
Fire0nic3's Avatar
The problem with cutting it out is that you will have nothing to press the new bushing in.
I used this to press mine out and then back in:
http://m.harborfreight.com/6-ton-a-f...ress-1666.html
Paid for itself after the first use. Shops charge $150 and up just for compression rod bushing replacement labor.
Old Nov 8, 2015 | 07:42 PM
Fire0nic3's Avatar
Also if you want to press in new busbings in the lower control arms and upper control arms, the press makes a quick job of it.
Old Nov 8, 2015 | 09:10 PM
ScraggleRock's Avatar
That's only the Armstrong or rubber ones tho. Energy and white line are a 3-piece design; you just push em in by hand.
Old Nov 8, 2015 | 10:35 PM
yosip1115's Avatar
And they last almost indefinitely. It's a no brainer.
For the LCA bushings I used a vice and a socket to press them in.
I have always had access to presses; I used to be in engineering at a company that made them along with rotary index tables, and other automated machinery. There is no need for a press IMO.
magnetism80
Feb 1, 2019 10:00 AM
snic09
Nov 8, 2017 01:46 PM
boostelevator
Brakes
Oct 5, 2015 08:56 AM
Roddy914
Aug 31, 2015 07:07 PM
RemmyZero
Aug 22, 2015 11:38 AM
