Headlights keep going out on 2003
Old Dec 8, 2015 | 05:01 PM
alwayson's Avatar
Question Headlights keep going out on 2003
Been doing it for more than a year.
Whats the fix?
Is there an LED swap?
Old Dec 8, 2015 | 06:02 PM
telcoman's Avatar
Veteran: Army
Whats the fix?
Follow the troubleshooting steps in the FSM
http://www.nicoclub.com/FSM/G35/Sedan/2003/lt.pdf
BCM, IPDM, wiring harness?
Good luck
Telcoman
Old Dec 9, 2015 | 09:10 AM
Mustang5L5's Avatar
Whats the fix?
Need more info. What's the problem?
The headlight bulbs blow? They randomly shut off? They flicker?
Old Dec 9, 2015 | 05:18 PM
alwayson's Avatar
They blow
Old Dec 9, 2015 | 05:35 PM
Lartytiejdke3's Avatar
so your headlights arent alwayson ?
Old Dec 9, 2015 | 07:33 PM
5150DS's Avatar
How long does it take for them to "blow"? Do both of them "blow"at the same time? What brand bulbs are you using? Is it HID bulbs or halogen?
Old Dec 9, 2015 | 07:38 PM
alwayson's Avatar
Halogen.
No, they don't blow at the same time.
I've tried many different bulbs from local stores.
Every 2 months approximately.
Yes, I know not to touch bulb.
Old Dec 10, 2015 | 09:16 AM
Mustang5L5's Avatar
Do your lenses fog up? Does water get inside?
Any moisture inside headlight housings that gets on the bulb will blow the bulb. Only takes a little drop of water on a hot bulb to crack it.
Old Dec 10, 2015 | 09:24 AM
alwayson's Avatar
Not sure.
Anyway, what about LED conversions?
Old Dec 10, 2015 | 02:28 PM
Mustang5L5's Avatar
Not sure.
Then this is what you need to look into
Aftermarket LED headlight conversions don't exist yet. They aren't plug and play like HID bulbs.
HID bulbs would pop just as well if you converted if moisture is your issue. You really need to find the root cause to your issue
Old Dec 10, 2015 | 02:44 PM
alwayson's Avatar
Old Dec 10, 2015 | 03:37 PM
Mustang5L5's Avatar
I really don't consider plug and play conversions to be anything near an OEM, engineered LED headlamp system which consist of a few LED's and properly designed reflectors
Another question. When your bulbs blow, does the glass shatter?
GARRYDG07
Lights
Feb 12, 2016 05:44 PM
35reilly
Forced Induction
Nov 26, 2015 10:00 PM
Crisci33
Nov 14, 2015 10:39 AM
digital sol
Lighting
Nov 5, 2015 11:53 PM
Gabe83714
Oct 6, 2015 06:40 AM
