2003.5 Radiator Fan (I Think) Noise
Old Jun 14, 2016 | 01:57 PM
IAreBob's Avatar
So, first off, this only happens when the engine is heated up. As I'm sure you all know, when the engine is warmed up and idling, the fan spins full blast. The thing is, when I turn off the engine, the fan usually makes a grinding type of sound as it comes to a stop. I'd like to know if this is normal or if I should have it inspected.
I'll try to post a video in a few hours when I get home.
Old Jun 14, 2016 | 05:11 PM
IAreBob's Avatar
My step father has informed me that it's the A/C coming to a stop, and that he believes this is normal.
Old Jun 14, 2016 | 07:29 PM
Mustang5L5's Avatar
A/C's don't grind to a stop. When you shut off the engine, the compressor stops instantly. No noise, period.
If something is "grinding" down to a stop, you want to investigate that. If it's the engine cooling fan, it's possible the motor is on it's way out.
Old Jun 15, 2016 | 05:32 PM
IAreBob's Avatar
is a video of it. Excuse the bad audio quality, my phone doesn't like audio for some reason. You can definitely hear the noise when the engine is cut off. I also turned it over and lightly revved it and let it idle a bit, then turned it off again with no noise.
I'm fairly certain it only happens on hot days (+80° F) and after the engine has already been running for a while, like after driving.
Old Jun 17, 2016 | 09:46 AM
Mustang5L5's Avatar
I hear the noise. No clue what it is though as I've never heard that before. If you notice, your accessory belt is stopped, but the noise continues, so not sure it's anything in the belt setup.
Does it make it if you turned off the A?C first, and then shut it down?
Old Jun 17, 2016 | 11:20 AM
IAreBob's Avatar
I rarely turn the A/C on. I'm usually driving windows down. The last time I had it on when I shut the engine off was too long ago for me to remember. The fact that it doesn't always make that noise is strange.. I really have no clue what causes it.
pauly1995
May 1, 2016 09:57 PM
mtlruss
Apr 26, 2016 09:20 PM
Black_Out
Apr 12, 2016 09:13 PM
bongoz
Mar 29, 2016 10:46 PM
kurier44a
Mar 20, 2016 04:57 PM
