Moog Endlinks Crap
Old 02-12-2017, 01:10 PM
Fire0nic3's Avatar
Moog Endlinks Crap
I installed these endlinks like 3 weeks ago. Probably put about 700 miles on them since. Started hearing a knocking sound that sounded worn endlinks over the past few days. I get under the car to check the suspension, and the right endlink and balljoint completely separated.
Guess ill go with OEM
Old 02-12-2017, 01:53 PM
.cakestar's Avatar
i have had my powergrids for 4 years with no issues. id highly recommend them
Old 02-12-2017, 02:02 PM
ScraggleRock's Avatar
Are you hella low? They aren't adjustable, so if yer super low yer gonna have all kinds of pre load on them; they weren't made for that.
Old 02-12-2017, 02:07 PM
Fire0nic3's Avatar
Nope not even close to low lol. Im dropped 1". Still a 1.5" wheel gap.
Old 02-12-2017, 02:17 PM
Yeah, they shouldn't have busted cuz of that. Sometimes you just get bum parts. Happened to my buddy once with his whiteline end links believe it or not.
I'd be willing to bet they'll give you a new set if you asked.
Old 02-12-2017, 02:32 PM
.cakestar's Avatar
since these arent adjustable what benefits do these have over stock?
Old 02-12-2017, 03:07 PM
LoSt180's Avatar
nothing, they're stock replacement parts. I've got about 24k miles on AC Delco endlinks that I got from Rockauto. Replaced all 4, still good.
Old 02-12-2017, 03:25 PM
They're definitely beefier than the stock ones, but I believe the Moog's have built in zerk fittings too. Other than that, they're just stock replacement parts.
Old 02-12-2017, 05:22 PM
Urbanengineer's Avatar
Received 1,018 Likes on 936 Posts
Yep ^ if you are lowered at all there are stresses on the system that were never there before. It will cause certain parts to wear out faster then they should.
Make sure you grease the new ones.
Old 02-12-2017, 08:00 PM
.cakestar's Avatar
yeah. i mean if you are going to lower the car at all i would definitely recommend adjustable ones and an adjustable sway bar
