G35x sedan: Anyone repair broken muffler with band clamp?
May 2, 2017 | 08:57 AM
Hi Guys, I have a 2006 G35 four door. My muffler has rusted completely separate from the mid pipe right at the connection/clamping (see attached picture). All I want to do is crawl under and use something like a
to reconnect. Has anyone tried this? One big question I have if you were successful is how did you clear off the old saddle clamping?
Any tips on success and failure appreciated. I went to a reputable muffler shop that quoted $775 to replace the mid pipe and muffler. I don't think that is really what is needed here to solve this. Cheers.
Pipe clamps rusted apart
Different angle
Close up side view
Reply 0
May 4, 2017 | 08:48 PM
You can get an after market exhaust for less than that.
Here is what seems to be an OEM level complete replacement for $359.
https://www.upsw.com/2004-infiniti-g...xK8aAvTq8P8HAQ
Reply 0
May 9, 2017 | 02:55 PM
I had this happen to me earlier this year. Cheapest solution is just go to a exhaust shop and have them weld the two pieces together with a small coupler. Cost about $40 total
Reply 0
May 11, 2017 | 03:48 PM
Quote: I had this happen to me earlier this year. Cheapest solution is just go to a exhaust shop and have them weld the two pieces together with a small coupler. Cost about $40 total
I did the same on my 05 G35x. I went to my muffler shop, and they weld a piece of pipe in between it, to connect both pieces. Cost me like $80; but it's fine now.
Reply 0
May 11, 2017 | 10:29 PM
Never repaired a muffler like that! I did use wire hangers to hold up my tail pipes on my first car when I was 15! Thank God, muffler shops that can do the job right without all the Mickey Mouse b.S.!
Gary
Reply 0
May 12, 2017 | 04:26 PM
My son's Camry was similar to that, the shop said they couldn't fix it without replacing most of the exhaust and the muffler since everything was rusted out.
Reply 0
