Are the 2006 and 2005 G35 RWD automatic transmissions interchageable?
Old Jun 5, 2017 | 05:37 PM
Billimon's Avatar
I have a 2005 G35 RWD Coupe that is having transmission problems. My simple question is if I can install a 2006 RWD G35 coupe transmission in my 2005 car.
Old Jun 6, 2017 | 07:31 AM
Blue Dream's Avatar
I drove ttrank's car solo
Simple answer is yes, they should be plug and play as long as you buy the right type, manual or automatic.
Old Jun 30, 2017 | 11:59 PM
PsGsedan's Avatar
03-06 transmission
Do you know if 03-06 automatic transmission g35 sedan are all compatible
Old Jul 1, 2017 | 02:56 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Depends on production month of the transmission if you have an '03, the cutoffs are "pre 09-2003" and "from 10-2003" verified with my local scrap yard, had to do a little research because this question has come up a couple times the last few days. Anything '04 to '06 is compatible for auto sedans.
You can check the ID number on the transmission to verify, no clue what visual indicators would be, You MIGHT need the transmission wiring harness, there are two different plug options on the transmission itself but the plug that goes into it will have the same 3 connections to the vehicle.
Old Jul 1, 2017 | 10:05 PM
PsGsedan's Avatar
Thank you, that just cleared up my question. I'm going to buy an 04 g35 sedan automatic transmission to put in my 05 sedan
Old Jul 13, 2017 | 11:20 AM
Billimon's Avatar
I forgot to mention is automatic. Thanks
Old Sep 13, 2017 | 10:57 PM
Billimon's Avatar
I did the interchange a few weeks ago. It works great.
Old Sep 13, 2017 | 11:04 PM
cleric670's Avatar
BANNED!!!
Awesome, glad it worked out for you!
Old Aug 10, 2022 | 03:47 PM
J.Vasquez's Avatar
Infiniti G35 Coupe
I just want to double check, i also have a 2005 auto G35 coupe that i want to do a tranny swap off a 2006 auto coupe. Your saying it worked no issues or ECU swapping?
Old Aug 12, 2022 | 12:00 PM
cleric670's Avatar
BANNED!!!
Replied to your other thread.
Plur
Jul 23, 2017 12:02 PM
James Andow
Forced Induction
May 31, 2017 07:52 PM
ig3506
May 28, 2017 08:17 PM
ig3506
May 23, 2017 10:09 AM
Mardwin Rosario
May 19, 2017 12:25 AM
