engine problems with my 05
Old Jun 5, 2018 | 09:19 PM
MgMatt's Avatar
Okay, so yesterday, On cold start it seemed to have problems starting, but after i tried for a second time, it started up fine with no signs of anything wrong. Drove around for a while before going home. Parked for a little bit and decided I needed some food, it took a try or two to start and it was fine, until halfway there the slip, vdc off, and service engine came on. I managed to get there and get food as well as get home alright. Today after work, decided to go to the auto parts store to get the codes read. After I decided I needed some milk and as i go to pull into a spot my car stalls. I decided I was already here so I might as well shop, anyways, Again, it took a couple tries to start but now again all the lights were on.
Autozone gave me the printout, which says its P0345 Camshaft Position (CMP) Sensor Bank 2 Circuit... Which I believe is the sensor on the passengers side correct? Well, I just had this done like a couple hundred miles ago. Think it could be defective?
Funnily enough, but worth mentioning, the suggested parts is a distributor?
Old Jun 5, 2018 | 09:27 PM
Blue Dream's Avatar
I drove ttrank's car solo
Bank 2 is the driver's side (angled sensor) and if you didn't replace it with an OEM sensor I almost guarantee that's the issue. It's a well documented fact on here that our motors don't always play nice with aftermarket sensors. Some have had long term success with them but the majority haven't. I found Amazon to be the consistently cheapest place to buy the OEM's but someone else recently posted they had found them even cheaper somewhere else. For the life of me I can't find that thread/post for some reason.
Old Jun 5, 2018 | 09:59 PM
MgMatt's Avatar
Awesome, You helped me solve my problem, good thing I keep good notes, It appears the code I got before was P0340 and now is P0345.I guess my memory was bad on which one was which. I'll look up a video of where it's located.Appreciate it man!
Old Jun 6, 2018 | 12:26 AM
Magneu's Avatar
5 Year Member
G35C 5AT
If you can, I'd swap both. If one goes out, it can indicate the other is going to follow soon after. Definitely go OEM as BlueDream said, I used Duralast and have been having some issues only six months down the road.
Old Jun 6, 2018 | 08:02 AM
Blue Dream's Avatar
The bank 2 sensor is on the back of the block facing the firewall underneath the throttle body. I took off the TB for easier access and it's a simple procedure. Of course there are instructions here and YouTube videos that helped me. Good luck.
Old Jun 6, 2018 | 04:25 PM
scumbagsleeper's Avatar
1990 Mustang GT - 351W Lightning bored/stroked 383CI TFS heads 78mm Turbonetics huricane
I changed both of mine without removing anything but the sensors. Have to do it from the passenger side and reach under the intake manifold/throttlebody area. All you need is a 1/4 drive 10mm long socket and some muscle to pull the connectors and sensors out. I thought I would try the Ebay specials and they lasted 2 days, I went through the cheapest infiniti dealer online to make sure the next sensors were genuine.
KPierson
Forced Induction
14
Mar 28, 2005 01:35 AM
Daveunch
Mar 18, 2005 02:58 PM
Daveunch
Mar 15, 2005 05:50 PM
nuttyprof
Apr 10, 2004 09:02 PM
uteric
Dec 19, 2003 01:08 AM
