Battery and brake light
Old Jun 20, 2018 | 04:00 AM
Cashiz89's Avatar
Infiniti G35 Sedan
Hey guys so I have an 06 g35 sedan and my battery and break light flash when driving. After a while my vdc and slip light comes on causing my gas peddle to give out. The car doesn't cut off but it won't allow me to accelerate. I've checked my alternator and switched my battery terminals. Still does the same thing. Anyone experience this issue?
Old Jun 20, 2018 | 04:56 AM
Blue Dream's Avatar
I drove ttrank's car solo
Do you have the SES light on in the cluster? It sounds like your car is going into limp mode. A lot of electrical gremlins can pop up on our cars when the battery starts to fail so check that first. A multi-meter can be useful but a hydrometer is best if your battery has cells you can open up and test individually.
Old Jun 20, 2018 | 07:20 AM
Urbanengineer's Avatar
Battery probably is failing.
Old Jun 20, 2018 | 07:21 AM
What voltage are you getting at idle, and 2k RPM?
Old Jun 20, 2018 | 08:11 AM
telcoman's Avatar
Veteran: Army
Telcoman
Old Jun 20, 2018 | 08:14 AM
telcoman's Avatar
Veteran: Army
Idle 12.3 to 12.6
2k RPM
Telcoman
Old Jun 20, 2018 | 09:56 AM
Well you aren't OP. Telco im asking him hahahah.
Old Jun 20, 2018 | 10:07 AM
telcoman's Avatar
Veteran: Army
I know. Just trying to explain to the OP what to look for/check.
Most likely he doesn't even own a meter or a hydrometer?
Telcoman
Old Jun 20, 2018 | 02:27 PM
Cashiz89's Avatar
Infiniti G35 Sedan
No SES light is on. Gave it a jump and as I drove it my vdc,slip,brake,snd battery light come on. My guadges went crazy and all the lights turned off. My Rpm guadge fell all the way to the bottom. Just took my battery to oriellys to be checked. I'll soon find out if that's it.
jakeup93
Nov 30, 2025 04:16 PM
thaistyle
Jun 4, 2022 08:00 AM
divito
Jun 9, 2014 10:01 AM
LR-G
Oct 14, 2012 10:49 AM
VQPWNAGE03
Aug 31, 2007 02:19 AM
