which version of automatic transmission?
how do you know which auto trans you have? I have we have the RE5R05A transmission but how do you know which version? I need to know which design of valve body solenoid is in my auto transmission.
thank you.
thank you.
Basically there are only two major versions and you can tell them apart with the wiring harness, one has a single large harness that plugs directly into the transmission, one has 3 wired coming out of that same spot in the transmission with 3 separate little harnesses than have green plugs.
I think the TCM are interchangeable as long as you have the correct plug style. The earlier 3 green harness was the external TCM mounted next to the ECU, the later single plug was the internal TCM style.
I think the valve bodies were all completely interchangeable even though they technically had different part numbers based on tranny revision. If someone else doesn't chime in I can try to get ahold of my tranny guy this weekend but I think he's taking the family on vacation because school got out.
The external TCM was only '03 and some '04 equipped G's.
I'm "pretty" sure they're interchangeable, they might have different revision markers but the function is the same. Sometimes you get things like mid-year revisions for solenoids because the manufacturer found a better deal on sourced parts. They might be made in a different solenoid plant but they meet the same specs and externally look identical but the board will have a different revision number so it's technically "different" even though it's 100% interchangeable.
A visual comparison would tell the story, you might also call around to local wrecking yards and ask them to look up the parts interchange on it. Their master interchange catalog is usually VERY accurate for what will or will not actually work.
2003 AT differences
Can anyone tell me the differences between the AT made from 08/02-11/02 and then 11/02+. I have a 2003 sedan AT and i will need a new tranny soon. Will any of the 2003 transmissions fit, and will only a 2003 version fit? or can i use a 2004 transmission also?
thanks!!
thanks!!
t7n7
Feb 27, 2024 09:56 PM
MrPotatoeHead
Nov 17, 2006 01:16 PM
