Cracked High Flow Catalytic Converter...
Old Sep 11, 2018 | 12:44 AM
03ncleosedan's Avatar
My 03 sedan sounded funny after spending a weekend with a relative from out of tow in need. Further inspection revealed a crack along the lower weld of the cat just before the y pipe. Is this weldable? Thanks in advance.
Old Sep 11, 2018 | 06:15 AM
Blue Dream's Avatar
I drove ttrank's car solo
A picture would help but I would think it's fixable depending on the size of the crack.. What brand are your HFC's?
Old Sep 11, 2018 | 05:00 PM
Scottwax's Avatar
5 Year Member
6 speed G35 sedan
I had a hole in my J-pipe on my Accord and a muffler shop was able to weld it up. Months later its still holding. Good thing too, $450 to replace it if that didn't work. So along a weld it should be fixable.
Old Sep 11, 2018 | 07:13 PM
gary c's Avatar
Welding a converter or even trying to patch it is questionable due to the massive heat! A better idea is to replace it with new Fast Intention HFC's! Ask your favorite Muffler Shop, they'll know how there welds hold with converters!
Gary
Old Sep 11, 2018 | 08:06 PM
Blue Dream's Avatar
Gary there are factory welds up and down the exhaust system and they seem to do just fine but the FI suggestion is a good one for sure.
Old Sep 12, 2018 | 08:57 PM
Uploading as we speak. It was the APS High Flows.
https://g35driver.com/forums/engine-...-s-vq35de.html
Old Sep 12, 2018 | 09:04 PM
Old Sep 13, 2018 | 07:19 AM
Blue Dream's Avatar
Damn that's not just a crack. With a hole that large I'm guessing you'll have to replace it. Sucks because they look like they were well made.
Old Sep 15, 2018 | 08:27 PM
Brother, I was loving them. Didnt have them a year and this happened
Old Sep 16, 2018 | 01:43 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
I suspect something impacted and fractured the metal, typically the metal used for cats is a softer grade but I've never used APS stuff. Call and talk to APS to see if they can repair it or perhaps give you a steep discount on a replacement since it broke evenly on the weld and that usually means a shallow tig weld thus a manufacture defect.
You can also shop around a local metal fab to see if anyone can just tig it back together, should be able to filler over that hole with a few passes and since it's such a clean process I doubt it would damage the media inside, might look a little wierd when they're done though.
EDIT: I would probably stay away from muffler shops for that repair unless they do a lot of tig welding, most exhaust shops just use DC stick weld. You need someone that does a lot of tig so a commercial welder that does industrial work will probably be your best bet. Also try your local community college if you end up with a steep repair price, the colleges usually have a welding certification program and they will have a student do the fix for welding practice.
Old Sep 16, 2018 | 05:47 PM
There is a local muffler shop that does fantastic work. I will check with them 1st.
Old Sep 24, 2018 | 10:38 AM
A shop near my house actually does alot of custom work and race projects. They welded it up and 40 later, I'm sounding like I should. Other than heat coming from the lower driver side seat (I have had this for some time) no major issues to report. Appreciate all the help!
Old Sep 24, 2018 | 11:47 AM
cleric670's Avatar
BANNED!!!
Awesome, glad you got it all worked out.
cgerson
Intake & Exhaust
26
Aug 31, 2009 12:29 PM
billybrun
Archived Sales
Sep 18, 2008 04:07 PM
GuLater
Intake & Exhaust
Jan 26, 2005 02:57 PM
