Wheel Stud Repair
Old Nov 13, 2018 | 02:34 AM
fitgineer_93's Avatar
Wheel Stud Repair
Has anyone replaced a wheel stud on their G themselves? I drive an 05 sedan; yesterday on a road trip I started to experience some vibrations coming from the rear with a lot of road noise. After I pulled over I found that one of the bolts on the left rear wheel was missing, and the stud was sheared right off. Honestly, I have no idea how this happened. I know for a fact I didn't over torque my wheels, or strip the lug nut and tighten it crooked when I put my winters on. My only guess is I forgot to re-torque my wheels, causing the nuts to back out after driving for a bit and cause extra stress on the studs. But even this doesn't seem valid as I can't see myself forgetting to perform such a simple task.
Anywho, I'm wondering if anyone knows of a DIY for replacing the studs. I don't think there's much room behind the hub to get a stud remover in there...
On another note, my right rear has waaaay too much play when pulling the wheel while holding it at the 3&9 positions. Looks like I might have to replace the bearing and hub assembly.
Old Nov 13, 2018 | 06:25 AM
eazdaskeez's Avatar
Easy peasy, just changed 2 of mines last week. Try to get the hole of the one your changing positioned at 12 o clock and slip the new stud in from behind the hub bearing (assuming you've already hammered out the old one) next get some washers (about 6 or 7) and slide them over the stud and use a lugnut and a ratchet to pull the stud forward while you tightening it. Works everytime for me
Old Nov 13, 2018 | 02:25 PM
And this was on your front hubs, or rear?
Old Nov 13, 2018 | 03:03 PM
eazdaskeez's Avatar
These were the rear
Old Nov 13, 2018 | 05:47 PM
Blue Dream's Avatar
I drove ttrank's car solo
The process is the same whether it's the front or the rear. That's how I've always replaced mine.
Old Sep 9, 2019 | 12:00 AM
Terence Wong's Avatar
2005 Infiniti G35 Sedan RWD automatic
Anyone have a video or YouTube link to this process? Or any step by step instructions from the start? Thanks in advance
g35kurt95
Nov 8, 2018 10:40 AM
ramo
Jan 4, 2011 03:07 AM
Back2VQ
Jul 17, 2006 01:23 AM
SammyJL
May 14, 2003 11:13 PM
