Dealer wants $1600 to replace ECM
Old Apr 25, 2019 | 04:51 PM
Joe2324's Avatar
Infinit G35 sedan
I got a p0507 code on my car and it won't pass smog- took it to a local mechanic who changed out throttle body and and then told me that the code can't be erased without the dealership due to some computer error. Took it to the Infinit dealer and they are telling me I have a bad ECM that needs to replaced for $1600. Is this something that another mechanic can do or just the infinity dealer? I feel like I may have to pay it as my previous mechanic just sent me to the dealership and said only THEY can deal with it with their computer systems. Should I try and install a used one from eBay myself and then have the dealership recompute? $1600 sounds like about how much the car is worth-- or is my cheapest option to just junk the car.
Old Apr 25, 2019 | 05:06 PM
Henry0844's Avatar
my dollar g, 05 Rev up with sport package
look around on ebay, I'm sure you could find one for waaaaay cheaper there.
Old Apr 25, 2019 | 05:35 PM
Joe2324's Avatar
Infinit G35 sedan
found some on eBay for $100- $200. But even if I install it do u know if I still need them to reprogram it etc?
Old Apr 25, 2019 | 05:41 PM
scumbagsleeper's Avatar
1990 Mustang GT - 351W Lightning bored/stroked 383CI TFS heads 78mm Turbonetics huricane
You will need a BCM/ECU and chipped keys programmed to match each other. PM me with year and car info. I can probably help you out.
Old Apr 25, 2019 | 07:16 PM
Henry0844's Avatar
short of going to the dealer for reprogramming of necessary items, not sure what else you need.
Old Apr 25, 2019 | 09:27 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Consult 2 dealership tool or Nissan Datascan 2 on a PC with the correct interface cable and the BCM serial number decoded.
Old Apr 25, 2019 | 09:30 PM
cleric670's Avatar
BANNED!!!
Biggest thing is to make sure you get the correct ECM, the numbers will match PERFECTLY, if not then it's the wrong one.
Old Apr 26, 2019 | 01:25 PM
Joe2324's Avatar
Infinit G35 sedan
Thanks for all the info - sounds above my skill level but I’ll hold off on the dealership for now and see if I can attempt a diy fix- if unsuccessful I’ll be forced to deal with the dealership or sell the car— dumb thing is the car works perfectly but just can’t pass a smog without the code clearing and I can’t just clear the code with a simple Ecu reset/ idle relearn: insane I may be out $1600 to clear a light.
Old Apr 26, 2019 | 02:09 PM
Henry0844's Avatar
it's 1600$ vs buying a new car, if it were me I would just pay the 1600$ because it would be much cheaper than buying a new car and having payments, assuming you don't have any right now. maybe give seb at specialty z a call and see what he would recommend. I'm sure he knows how to get it done without a dealer visit. good luck!
Old Apr 26, 2019 | 10:32 PM
cleric670's Avatar
BANNED!!!
If it's running perfectly then I suspect the ECM isn't the problem. Unless it's the memory error DTC. Exactly what code is it throwing?
jparker7269
Jan 14, 2019 09:19 PM
almatti
V36 Engine, Exhaust, Drivetrain & FI
28
Feb 24, 2010 10:58 PM
6969g35
Jul 1, 2005 11:24 AM
MikeStarrG35
Jun 20, 2005 11:31 PM
moosehog
Dec 24, 2003 10:56 AM
