Is there a fix for the faulty fuel gauge/filling problem yet? (2007 G35X Sedan)
Old Jun 17, 2019 | 03:01 PM
thisdugan's Avatar
G35X
Has anyone figured out a proper fix for this?
My fuel gauge displays an almost random value usually between 1/2 and 3/4 full. The car now refuses to take more than about a gallon of fuel and it has become impossible to track how much fuel I have left with the combination of these issues.
I have tried cleaning the fuel level sensor, as well as running the dash cluster diagnostic which showed that the dash appears to be working.
The car is at 160k, so I do not think any warranty options apply to me at this point sadly.
Old Jun 17, 2019 | 03:22 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Yes, there have existed fixes for both those issues since they were first discovered.
Verify proper resistance readings at the fuel pump sub harness and primary harness, values to check are listed in the FSM under section DI - Driver Information under the fuel gauge section. If the resistance values are correct then the combination meter will need to be replaced.
Fuel filling problem is the EVAP vent tube that goes from the tank back up to the fill neck, it accumulates grime over time which restricts airflow to the point you cannot fill the tank above the halfway point. Remove the tank and replace the hose.
https://nicoclub.com/archives/infini...e-manuals.html
Mr7
Jan 17, 2017 11:04 AM
iTzTeddy
Apr 13, 2016 06:18 PM
DFWTXG35
Apr 14, 2014 04:43 PM
davistld01
Mar 20, 2006 01:27 PM
