Rust Rust Rust
Old Nov 29, 2019 | 01:22 PM
ProjectG35x's Avatar
G35x Premium Package
Rust Rust Rust
What have folks been doing to fix or prevent all the rusting that happens underneath the car? Trying to fix/restore a project car and its pretty bad.
Old Nov 29, 2019 | 07:42 PM
Scottwax's Avatar
5 Year Member
6 speed G35 sedan
For what proper rust repair can run you'd probably be better off finding a rust free car from outside the rust belt. If you have to replace floor pans, trunk pans, suspension components, lower sections of body panels, etc its really expensive. As in more than the car is worth to fix properly.
Rust isn't an issue here in north Texas, both my cars look pristine underneath.
Old Nov 30, 2019 | 08:46 PM
Have you guys tried using 3M Pro Grade Rubberized Undercoating or Cosmoline RP-342?
Old Dec 1, 2019 | 12:44 PM
scumbagsleeper's Avatar
1990 Mustang GT - 351W Lightning bored/stroked 383CI TFS heads 78mm Turbonetics huricane
My 04' 125k G was from PA and it had rust everywhere. My 05' 150k G was from TX and doesn't have 1 spot on it. Rust repair is a tricky thing, you have to really get in there and do it right or it's just going to haunt you later. Honestly I wouldn't spend the time and money to repair rust problems as cheap as the 03'-08' cars are getting.
Old Dec 1, 2019 | 01:43 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
I only rust repair vehicles I plan on keeping forever, my GMC Sierra is pretty thrashed all over with quite a bit of rust on the bed but I'm definitely not going to be fixing that rust... I think... maybe I'll just buy another bed someday
Old Dec 2, 2019 | 08:11 AM
Scottwax's Avatar
5 Year Member
6 speed G35 sedan
That's good to prevent rust in the future but if you already have rust it won't do much. Certainly won't fix it.
Old Dec 3, 2019 | 06:16 PM
speedkar9's Avatar
Infiniti G35
Since these cars are getting old, its not worth fixing the proper way (replacing the metal).
The best bet is to slow the rust down, by sanding off as much as you can, prime and paint it to keep it protected from the elements. Wash the car frequently in the winter.
vashawn
Jun 23, 2017 11:53 AM
jcrayamsterdam
Dec 12, 2014 09:20 AM
Muski_G
Apr 20, 2014 08:07 PM
RedBaronK
Jun 12, 2011 03:59 PM
RedBaronK
Apr 2, 2011 09:29 PM
