5AT trans cooler banjo bolt size needed.
Old Dec 17, 2019 | 08:07 PM
G35namedfranny's Avatar
G35 Sedan, high compression,Poncams,exhaust,porting to heads and intake,lowered on coilovers,tuned
I am needing to replace my trans cooler lines. I need to know the specs of the stock banjo bolt so i can order the parts needed to make an6 cooler lines going to my afternarket cooler.
Old Dec 19, 2019 | 01:31 PM
ProjectG35x's Avatar
G35x Premium Package
This is a project of mine too. You will need to take off the Y-pipe to gain access to the 17mm banjo bolts
https://www.infinitipartsdeal.com/pa...310_C002,21625
Old Jan 16, 2020 | 10:34 PM
i have a HR style Megan Y pipe and it doesn't require removal to get to them.
for anyone looking I bought some m14x1.5 to -an6 and they fit fine.
Once again the banjo bolts are m14x1.5.
Old Jan 17, 2020 | 12:57 PM
Is the Megan Y pipe that different that it gives you access to the banjo bolts?
Old Jan 17, 2020 | 01:06 PM
its like the vq35hr or 370z Y pipe. On my car which is a rwd it doesn't block it at all. Actually iirc i ordered the 370z pipe when i bought it 3 years ago.
Phalanx
Oct 30, 2013 06:56 PM
Vectork39
Jan 23, 2012 11:44 AM
djb703
Mar 16, 2011 12:04 AM
5150DS
Jun 22, 2010 10:56 AM
senupi
May 26, 2004 10:43 AM
