Help identifying an unknown wire.
Old Jan 7, 2022 | 02:23 PM
Devos11090's Avatar
Stock coupe
Hello, I have had the unfortunate experience of rats chewing my harness.
I need help identifying the last two wires for repair.
im under the brake booster and the main harness going back into the firewall has a two wire shoot off almost immediately in the brake booster pocket. The wire colors are white and black, both with a silver stripe.
I'm assuming the black is a ground, but I have no idea where it connected originally. If someone could identify them and maybe take a few pics of the routing I'd be eternally grateful.
I will be soldering these, so don't worry lol!
Old Jan 7, 2022 | 05:58 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Typically you can just keep removing wire loom until you find the other end of the wire.
Old Jan 7, 2022 | 06:05 PM
Devos11090's Avatar
Stock coupe
Totally understand, yet these two wires had their own loom that I took off to begin repairing. I just can't find where they might go.
Old Jan 7, 2022 | 06:08 PM
cleric670's Avatar
BANNED!!!
Well my G is sitting pathetically in the driveway all snowed in with a broken radiator so I'll go pop the hood and take a look.
Old Jan 7, 2022 | 06:28 PM
cleric670's Avatar
BANNED!!!
Well I went out and took some pictures of the wiper motor wiring because that's initially what I thought it was, now I don't think so.
What all do you have plugged in? Should be the wiper motor, ABS relay with the 3 harnesses, brake fluid level, brake fluid pressure sensor, ABS motor, and the ABS solenoids in the block.
Old Jan 8, 2022 | 01:08 AM
Devos11090's Avatar
Stock coupe
I found where the wires went! It is the master cylinder signal wires. I'm assuming to alert low brake fluid.
the rats had chewed all but an 1/8 of an inch sticking out from the connector..
I appreciate your time!
I had to take the booster put of the car along with the master cylinder which is why I didn't see it at first!
Old Jan 19, 2022 | 03:22 AM
alawa don's Avatar
bmw m3 i like alot blue color
Moderator EDIT: Well that's a first, banned for botting a Turkish citizenship website...
dlouly76
Aug 7, 2025 01:23 PM
blownvert
Nov 4, 2007 10:25 AM
thinhdle
Oct 19, 2007 07:09 PM
SagiSRP
Jun 15, 2005 03:49 PM
