TCM questions
Old Jul 12, 2022 | 02:09 PM
Sergd31's Avatar
G35
TCM questions
Hello all. So I'm having issues with TCM right now. I've tooken out the TCM multiple times and seems that the pin keeps breaking when I "abuse" the car a lil bit. Can I get a TCM from cars from other years and do I need to program a used TCM also or should I just get a new one and program it.
Old Jul 15, 2022 | 11:22 AM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
If it was a used TCM it doesn't require programming.
You could also use epoxy resin to build a little "reinforcement" for that pin to keep it from moving around. Something like JB Weld would be fine for that application just make sure to clean everything thoroughly with either brake cleaner or isopropyl alcohol so you get a good bond.
Are you making sure to clean the pin thoroughly and are you using flux?
Alternately I was thinking that pin is wide enough to be drilled out on either side then a jumper wire could be soldered into place.
Old Jul 27, 2022 | 01:15 PM
Sergd31's Avatar
G35
Yes I cleaned it well with 90% isopropyl..tried sanding it a bit too for a better bond. i just took the TCM today and soldered it again. I'll try that JB trick and maybe wrap it around the solder ( if you have a recommendation product, please let me know) or the drill a hole trick.
Ami
Feb 2, 2022 09:10 PM
quickspeed6
Drivetrain
Feb 10, 2020 06:13 PM
lowkeeg35
SFL G CLUB
19
Jul 9, 2012 01:45 PM
AmateuRN
Drivetrain
25
Mar 15, 2008 01:39 PM
