'03 G35 crank no start
Old Jul 19, 2022 | 08:50 PM
ecvsti's Avatar
G35 in prog
Unhappy '03 G35 crank no start
Alright so my car was initially down due to a blown transmission. Got everything replaced (CD009, new clutch, new flywheel, new clutch line) and I even did the rear main seal and the front seal. Opened up the upper oil pan and it was hell lol
put everything back and when I started the car, I thought I had an exhaust leak since my exhaust was cracked. took it to an exhaust shop and the guy said my car is misfiring. He said it shouldn't be sounding like a subaru 😂 the whole time I thought it was because of the exhaust leak. read the code and said I had a misfire on cylinder 2. changed the spark plug and the car sounded WAY better. sounded normal and the code was still coming up. changed the coil pack and the code went away.
The next day I was driving it and making sure everything was going smooth, my car stalls on me. I turn it back on and my car would stall on me at low rpms. The car would still start right back up though. I thought it was a vacuum leak or something. drove it back home stalling and turning the car back on. I checked and no leaks. I did the throttle relearn and I turned the car back on. My car was idling fine and it would not stall! I decided to test drive it and I messed up.
The car turned off on me in the middle of traffic! I tried turning it back on and it would crank, but not turn over. pushed it to a gas station nearby and tried to start it and nothing. I have a new battery and new alternator so it can't be that. A guy let me use his reader and it threw me the camshaft sensors. I tried to change them and nothing. I can hear my fuel pump, but I don't know if it can still not work even with it priming. OR it could be a clogged fuel filter. I'm hoping it's that because I don't want it to be the timing chain. That's my biggest fear lol. my injectors had fuel when I opened them up so I think that's good? Also heard it could be the MAF sensor, but I heard the car can still start without one or it could be hesitant when running at least.
Switched out the crankshaft position sensor so that's not it. Not sure why it could be the timing all of a sudden. My car was down for months too. 60k miles on my imported engine as well...I posted it for sale and they're trynna hoe me out for 2k smh
IF it is the timing chain, I'll sell it and get myself a subaru 😊😊
Old Jul 22, 2022 | 10:47 AM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
If you didn't use a Hitachi or a Genuine Nissan Parts OEM cam sensor then it's probably still a bad cam sensor. These engines don't play nice AT ALL with any aftermarket sensors.
Exactly what code did it throw?
Also, when trying to start the engine, while it cranks do you see the tach move? If not you could have a crank sensor went out as well. What condition was it in when you had it out for the transmission job? Also make sure that it's bolt is snug, if it backs out a little it won't read the flywheel pickups.
Ignore the exhaust sensor codes, you don't have the rev-up engine, the other stuff is the same though.
Old Jul 22, 2022 | 02:11 PM
ecvsti's Avatar
G35 in prog
[QUOTE=cleric670;7212553]If you didn't use a Hitachi or a Genuine Nissan Parts OEM cam sensor then it's probably still a bad cam sensor. These engines don't play nice AT ALL with any aftermarket sensors.
I got the P0340. I had a mechanic come over yesterday and he started the car but it was running rough. Im guessing the misfire came back so I’m going to swap all the sparkplugs this time.
Old Jul 22, 2022 | 03:26 PM
cleric670's Avatar
BANNED!!!
If the computer is throwing P0340 it's because there is a problem with either the sensor or the wiring or the cam tone ring. The ECM is literally telling you there's a problem with THAT sensor, not a misfire on a specific cylinder which will throw P0300 - P0306.
Now swapping out for fresh plugs isn't a bad idea, especially if they have 50k miles on them or so. But that's not going to make a cam sensor start working again. The ECM is reading the angle (frequency) sent from the sensor and seeing that there is missing or incomplete data being sent.
If the ECM thinks the cam angle is at a specific point but it's sending wrong, missing, or incomplete data then the ECM doesn't know exactly when to control fuel and ignition timing, this will make your engine run terribly.
mike730
Apr 24, 2020 10:52 PM
Alex Ant
Dec 13, 2019 10:20 AM
G Thunder
V36 General Tech Questions
Dec 11, 2013 09:45 AM
ImPoppi
Jul 24, 2012 10:58 PM
Skaterbasist
12
May 2, 2007 10:27 PM
