Weird loss of power
Old Apr 30, 2023 | 10:37 AM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
You'll get back your normal timing advance of 45 under throttle once you fix that knock sensor. The engine pulls a TON of timing when it's not reading it. Everything else sounds pretty normal
Old Apr 30, 2023 | 03:44 PM
Howardb's Avatar
G35 sedan
Thank you guys for all your help I changed out the wire using hangers and makeshift tools come to find out at the sensor side no wires were connected. Feels fast again and took me about 20 min. You guys are great
Old Apr 30, 2023 | 04:43 PM
cleric670's Avatar
BANNED!!!
Awesome, glad you got it all figured out.
Old May 4, 2023 | 10:37 AM
Howardb's Avatar
G35 sedan
Nope now it's feeling off again guys here's the numbers I'm looking at when it's running sluggish no codes and no pd codes either
Old May 5, 2023 | 08:48 PM
cleric670's Avatar
BANNED!!!
Log bank1, 2 CAMSHAFT advance and see what that's doing. With 30 degrees timing you should be around 40 degrees advance on the intake cams.
Old May 5, 2023 | 08:50 PM
Howardb's Avatar
G35 sedan
I will do tomorrow and get back to you
Old May 6, 2023 | 06:53 AM
BeanBby909's Avatar
Infiniti g35
Limp mode
Car is in limp mode right now driving normal like about 20 mph but if u pump on the gas a few times it drives fast as hell? So the car isn't reading any check engine light because it needs to be driven a certain amount of miles before it pops up again I'm on limp mode for almost 6 months my belt squeals so bad but the belt is newish I had to replace my battery several times until I looked more into this. My anti light is flashing even after unlocking the car so I noticed my passenger window wasn't going up or down which was odd cus I paid 250 for brand new motors to be install so it shouldn't have stopped working so my theory is my car was broken into or attempted to break into so caused my car to lock the anti theft alarm so with that being on my car automatically went into limp mode. Limp mode is an intelligent operating system but also difficult to resolve. I found out after changing window motors or locks you have to reprogram your car..after changing battery or unplugging u gotta reprogram car..same as radio system or spark plugs etc that being said once u reprogram what u need to reprogram dnt forget to reprogram your key as well once u get the limp mode or anti theft alarm to disarm then more then likely ur problems will be free
Old May 6, 2023 | 10:31 AM
cleric670's Avatar
BANNED!!!
If you're in limp mode you ARE throwing a code.
Old May 8, 2023 | 05:53 PM
jacobpew's Avatar
g35 sedan rwd
Advance/retard
Does anyone know what the maximum retard angle is for camshaft timing? Bank 1 stays at -17 unless the vvt solenoid is activated and then it matches the timing on bank 2
Old May 9, 2023 | 03:33 PM
Howardb's Avatar
G35 sedan
My scanner won't read cam timing just spark timing. Also my 02 upstream sensors at idle go from .06 volts to .76 fluctuating. I read if it drops below .10 or above 1.0 the sensor is not good but no codes for that on. Does that mean mine are not good idk if they ever been changed.
jjuriga
Jan 1, 2016 08:18 AM
vamarris
Sep 26, 2015 12:56 PM
STL_G
May 4, 2010 07:46 PM
mcaron
Oct 30, 2008 06:57 AM
bbboltz
Jun 7, 2007 12:51 PM
