6MT Worn Synchromesh?
Old Apr 7, 2005 | 11:56 AM
Edwin's Avatar
Hi,
I have a '03 6MT sedan with 28,000kms (17,388miles) which I bought used a month ago.
I have noticed that when shifting from 1st to 2nd gear it feels like the synchromesh is worn. I almost get the crunch...almost but not quite. I can definitely feel the gears meshing! This situation improves greatly when the gearbox is thoroughly warmed up.
I am concerned that the syncho is indeed worn. Can you guys share your experiences?
If it is worn, would this be a fix covered by the warranty?
Old Apr 7, 2005 | 12:20 PM
jmcumming's Avatar
I mentioned this on my '04 to the tech at my 7500 mile service (have more or less had it since day one). It's really only present when in stop and go traffic and I'm light on the throttle. If I am just crawling, and go into 2nd, it seems like the synchro doesn't keep up and I get a slight grind or can feel a little resistance. If I am heavier on the throttle and shift at a higher RPM, it's not a problem.
They didn't notice it, and it's sometimes hard to get it to duplicate. Will just be keeping an eye on it for the next service.
Old Apr 7, 2005 | 12:32 PM
hwy_star's Avatar
my car does the same thing.
Old Apr 7, 2005 | 12:48 PM
Texasscout's Avatar
Mine is brand new and I feel it also. However, it's mostly when I use sloppy clutch work.
Old Apr 7, 2005 | 02:27 PM
doogie's Avatar
You might try slapping some redline tranny fluid in there, it seems to help especially when temperature is an issue, hot or cold (stop and go traffic, or first thing in the morning)
Old Apr 7, 2005 | 07:45 PM
Edwin's Avatar
Thanks for the feedback guys. I can stop worrying now!
Old Apr 8, 2005 | 02:54 PM
transportchef's Avatar
05 6mt which has the same thing happening..
Old Apr 8, 2005 | 04:27 PM
Edwin's Avatar
I do remain concerned about the longer term durability of the synchromesh. Having the "crunch" can't be the best thing!
Old Apr 8, 2005 | 04:29 PM
vleo8181's Avatar
Yea...sucks. I thought they fixed it.
Tmatheso
Dec 13, 2015 03:24 PM
Blue Dream
Dec 5, 2015 10:56 AM
alessandro
Oct 8, 2015 09:29 AM
RWDguy4238
Sep 30, 2015 12:13 AM
