Best way to Launch a 5AT Sedan.
Old May 8, 2005 | 03:43 PM
05Blk's Avatar
Wondering how you guys with auto launch? Just WOT, or gas break to certain rpm? Which is better? VDC? I dont know. Need help on launching a 05 sedan.
Thanks
Old May 8, 2005 | 03:55 PM
RBull's Avatar
Rated M
I don't drive an auto but here's my thoughts. We'll see if others with autos agree.
VDC off
with foot on brake rev to about 1000 to eliminate driveline slack
mash throttle or modulate based on tire temps and road surface friction
Old May 8, 2005 | 04:59 PM
R8D G's Avatar
Florida G35 Club, Premier Member
This same topic was posted before, can't remember where. Do a search and you'll find all the info you need.
Old May 8, 2005 | 05:20 PM
arjunz's Avatar
VDC OFF.
Hold Rpm at 1500, 2000 .. and ...the Pedal to the Floor
Old May 8, 2005 | 05:49 PM
GeeWillikers's Avatar
Walking The Fine Line...
Hold brake, advance throttle quickly to 2000 RPM, release brake and hang on.
The search key would have rendered these results more quickly than waiting on responses.
Old May 8, 2005 | 09:09 PM
DaveB's Avatar
I took my G to the track for the first time this week and this is what I found worked best. VDC off, foot on brake, foot on gas to bring the rpms up to 800-900rpms to remove drivetrain slack, and when it's time to go, mash the gas to the floor, and almost instantly release the brakes. This resulted in low 2.2 60 foots. Mashing the gas without holding down the brake much resulted in a much slower 2.34 60 foot. My G barely chirped a tire on launch either. I think in cooler weather, mid 2.1 60 foots on the EL42 are attainable.
Old May 8, 2005 | 11:57 PM
skeleton_cru's Avatar
Sedan
Thumbs up
Great info with track times to back it up.
Old May 9, 2005 | 12:34 PM
ChicagoX's Avatar
Don't drink and Mag Race
I pulled 2.20-2.24's out of a loaner sedan by brake-torquing it to just over 2k rpm, then side-stepping the brake while flooring the gas.
My "X" car cuts 2.1's all day on EL42's, but the AWD helps a wee bit.
heynow
2nd Gen (V36) Sedan
Oct 28, 2015 05:09 PM
3-fity
Steering & Suspension
Sep 20, 2015 05:05 PM
ENTRAPM3NT
Sep 16, 2015 01:21 AM
Gwhut?
Drivetrain
Sep 6, 2015 10:07 AM
TrillO.G.35
Sep 5, 2015 02:06 AM
