Banging mid pipe
Banging mid pipe
My coupe mid pipe bangs on this small brace that’s between the drive shaft and the pipe. When I go over some really bumpy roads. Does anybody else have this problem? If so what did you guys do to stop this?
Take a look at this thread:
https://g35driver.com/forums/showthr...9&page=4&pp=15
Ivory_G mentioned that his mid-pipe was touching the cross brace, so he bent it a little so the mid-pipe would not bang into it.
I have the same issue, going to try to look into it tonight or tomorrow.
what i did when i had my mid pipe on i moved the little brace up one bolt hole so it was only held on with one bolt in the front on each side. not sure if it comprimised the strength but it still felt like it was pretty solid down there. it has now been put back in the right spot since i installed the fuji exhaust. oh, and i tweeked the heat sheil about a 1/4 inch to give a little more clearance.
i don't know if the coupe has the same brace but the brace i am talking about is on the sedan. it is little and grey and is held on with 4 bolts. just take it off and move it forward a bolt hole on both sides. it will keep it there and it will be able to be put back if needed with out having to bend it back.
