EZ way to change the oil filter?
Old May 16, 2005 | 06:38 PM
Streaker's Avatar
Question EZ way to change the oil filter?
I changed the oil in my "G" this morning. Yes, I got it all over my arms, the floor and anything else that was laying around collecting dust. No problem at all draining the crankcase but changing the filter was a pain in the tool box.
I was able to remove and replace it (without dropping the plastic undershield) by using a cup wrench and a universal fitting on a long extension.
Cleaning up the mess only took a few minutes and I'll certainly do it again.
My question is: Has anyone found a good/easy way to change the filter??
Thanks
Old May 16, 2005 | 07:02 PM
Xman's Avatar
Why don't you just drop the undershield? Then it's no sweat and clean. My $0.02.
Old May 16, 2005 | 07:30 PM
Msedanman's Avatar
O.F. Administrator
I've found it easiest to drop just the back end of the cover allowing easy access to the filter and drain plug.
For me it was too messy leaving the cover in place.
C.
Old May 16, 2005 | 07:34 PM
Panman1978's Avatar
I actually cut away just enough of the shield to get a good hold on the oil filter. I haven't noticed any adverse effects yet.
Old May 16, 2005 | 10:18 PM
shodog's Avatar
I have considered doing this also. The problem I see is that as your taking off the filter it tends to dribble all over the place. usually I have my pan under it to catch it. with jsut the small hole in the underbody diffuser, you run the risk of getting it all over the insed only to drip out for days later.
Old May 17, 2005 | 12:32 PM
jstwong's Avatar
Personally, I just cut out a larger hole in the diffuser as well.
Old May 17, 2005 | 11:44 PM
ryoken's Avatar
You've probably changed the coefficient of drag on your car from 0.27 to 0.2701. That's going to cost you 0.001 mpg.
Old May 18, 2005 | 04:10 AM
nuttyprof's Avatar
i just bring it to jiffy lube. 20 bucks to save that bit of trouble.
Old May 18, 2005 | 07:02 AM
RBull's Avatar
Rated M
I open up the back of the pan guard and let it dribble into my pan before fully removing. There is always a little mess but it's not too bad.
Old May 18, 2005 | 08:45 AM
Streaker's Avatar
Thumbs up Advice
Thanks guys.
I appreciate the feedback. I'm gonna do the undershield modification. Just cutting out a wee bit of that part cannot affect anything that I will be aware of. How much could it possibly change my coefficient of drag while I'm stuck in Atlanta traffic??
Old May 19, 2005 | 05:56 PM
Panman1978's Avatar
hehe. I think my mods already killed MPG!
brane123
Interior
Aug 23, 2015 06:55 AM
JoeMac
Aug 20, 2015 10:17 AM
Gookiecrunch
Aug 19, 2015 12:00 PM
ClwMike
Jul 23, 2015 12:55 PM
