Hot Outside Air Through Vents
Old May 26, 2005 | 01:52 AM
gordhead's Avatar
Anyone:
I have seen some posts to this issue before. I just cannot find the discussions.
The problem is running the vents without A/C. I still get signifcantly warmer air coming through the vents. Has anyone had this problem and know a fix?
The dealer said to turn on the A/C!
Thanks
GH in San Jose, CA
Old May 26, 2005 | 05:29 AM
skeleton_cru's Avatar
Sedan
Common issue. Unfortunately you get warm air when you try and get fresh air through the vents. What I usually do if I want fresh air is tilt the sunroof up and put the vents on recirculate. Or you can run the A/C one or two degrees lower then the outside temp.
Old May 26, 2005 | 08:00 AM
cato's Avatar
SouthernComfort Moderator
Oh man! This is an old issue. Check the DIY forum for a fix. The fix there is to apply silicon caulk around the battery compartment frame, as fresh air is sucked in from that area. the metal making the battery section does not meet flush and allows warm engine compartment air into the mix. I did it and it does help, but the fresh air without A/C will never be as cool as outside.
Old May 26, 2005 | 10:59 AM
doogie's Avatar
cato is that the lawnmower man?
Old May 26, 2005 | 11:14 AM
cato's Avatar
No, it is me after a couple of martinis.....
Old May 26, 2005 | 03:43 PM
trey.hutcheson's Avatar
No... it's Seraph, The Oracle's protector/warder/bouncer/bodyguard dude from the matrix Reloaded/Revolutions. At least that's what I think...
Old May 26, 2005 | 06:20 PM
DaveO's Avatar
Originally Posted by gordhead
Anyone:
Thanks
GH in San Jose, CA
I did a search and came up with a previous post.
https://g35driver.com/forums/showthr...ighlight=DaveO #25
Old May 26, 2005 | 10:07 PM
kbmuddyz's Avatar
Awesome...I love it when you give me a previous post that has a link to another previous post.
Old May 27, 2005 | 01:22 AM
Sedan
Beggars can't be choosers.
Old May 27, 2005 | 12:13 PM
gordhead's Avatar
Hot Air
Everyone:
Thanks for suggestions.
Still... This really sucks. I do not have this problem with any of my American vehicles.
p.s. I am taking my car in today to have the brakes fixed. At 22K miles, it sounds like the wheels are falling off.
GH
KallDay86
Jan 8, 2016 12:42 AM
hrdwirk1
Oct 2, 2015 06:34 PM
Learned Hand
Oct 1, 2015 09:02 AM
Jcruzg35
Sep 26, 2015 04:47 PM
master111
Sep 25, 2015 08:32 PM
