Another Case of dealer not checking tire psi on a new sedan!
Old May 31, 2005 | 08:39 PM
  #31
G35_coupe_6MT's Avatar
This happens when they have the cars on the lot. They pump the PSI higher than what it needs to be because they let them on the lot... Thats what my dealer told me, but if your car gets from Japan, they ask (if they remember) the service doods to put the PSI to 36.
Old May 31, 2005 | 08:46 PM
  #32
ABQ_G35's Avatar
Originally Posted by Corgidog
How stupid is Infiniti-why make a wallet key that doesn't operate the car is really dumb. "Hey I lost my key and hooray I can get in the car but boo hoo I can't drive it". Forces one to hide an ignition key in the car as insurance. dumb, da dumb dumb, dumb....
Not stupid at all, like Colin says, it's just to open your door should you lock your keys in the car, not if you lost your entire set of keys. I also carry my valet key on my house key ring.
Old May 31, 2005 | 09:21 PM
  #33
JKWright's Avatar
Originally Posted by SaltiDawg
The proper inflation pressure of your tire is not the highest pressure that you can get without exceeding the tire manufacturer's maximum. What is the vehicle manufacturer's recommended pressure, front and rear, as likely found on the door or door column?
May I call you Captain Obvious?
Eeaton was asking what Bridgestone's maximum recommended inflation pressure for the 18" Turanza is. And while Nissan's recommended tire pressures are stamped on a little decal stuck on the B-pillar, these are typically very conservative, ride-oriented pressures. I generally run a few pounds over these numbers for improved high-speed performance. (Read "a few pounds" as nowhere near 51 psi.)
Old May 31, 2005 | 10:41 PM
  #34
I never use the wallet key, it just bulks up my wallet. I cant even sit on my wallet as is (and its really thin). If I lose the key to my baby, I deserve for her to be stolen.
Old Jun 19, 2005 | 05:10 AM
  #35
slslsl's Avatar
Just checked my tire pressure for the first time since I bought my sedan a month ago. 44 PSI all the way around. Just ridiculous.
By the way, is there any damage that could've been done to my tires by driving around at such an inflated pressure for 1,000 miles?
Old Jun 19, 2005 | 01:25 PM
  #36
94gxe's Avatar
Manufacturer recommended tire pressures are not set to optimize tire performance and life but ride quality. IIRC a lot of the tire failures on SUV's several years ago were finally attributed to recommended tire pressures that were so low as to make the seriously overloaded with anything more than a minimum load in the vehicle. Why, to provide a nice soft ride. Overloaded tires are bad news. I generally start with inflation pressures 4 lbs higher than recommended and then adjust front and rear based on wear and handling.
Old Jun 19, 2005 | 01:47 PM
  #37
Msedanman's Avatar
O.F. Administrator
OVerinflating tires will cause the middle to wear more than the outside. The outside isn't able to sit properly on the pavement.
Similarly, if underinflated the outsides wear quicker.
C.
Old Jun 20, 2005 | 12:40 AM
  #38
basus's Avatar
I checked mine today for the first time in 4 mths and the tire pressures were 35-36 .... adjusted to 33.5 on cold tires and the car runs and feels much better -- shud have done earlier but think that the delaler must have inflated it in the recent oil change -- any tire damage would have done
Old Jun 20, 2005 | 08:35 AM
  #39
cfrago's Avatar
mine (04, 6mt sedan) came with 45 lbs all around also. had to bring it back to reset the tps........ such an easy thing to check, but so many emails with this problem.
Old Jun 20, 2005 | 08:55 AM
  #40
mickey3c's Avatar
All tires are inflated to max pressure before leaving the factory. This is done for a number of reasons, but the dealer should adjust them down to about 32psi which was done on my car. Scares the hell out of me if the dealer techs missed this. What else did they miss.!!!
3000vr4tt
Media Share V36 Sedan
Jan 4, 2023 03:20 PM
multimut
Wheels & Tires CDN
Apr 8, 2018 06:07 PM
joedaddy1
Jul 28, 2015 02:58 PM
multimut
Canada
Jul 26, 2015 08:43 PM
itschuckster
Jul 25, 2015 08:07 AM
