Installed aluminum pedals. Stopper on the gas pedal?
Old Jun 1, 2005 | 12:01 PM
DaveB's Avatar
I've done a search and can't find anything about this. I installed my aluminum pedals yesterday and noticed that the stock plastic gas pedal has a 1" travel stopper on the back. The replacement aluminum does not have this. I thought this was kind of odd. While scrolling through infiniti-parts.com I noticed they sell the aluminum pedal kit, but they specifically say that the G35 sedal kit DOES NOT include the gas pedal, though the coupe pedal kit does include the gas pedal. It only includes the foot rest and brake pedal. I was thinking it maybe had something to do with the shape of the floor board in the sedan, but the coupes floor board has the same exact shape and I wouldn't be surprised if the Z/FX is the same too. Looking at the DIY pedal install (on a coupe), the picture clearly shows the coupe plastic pedal with the stopper mounted to the bar that the peadl attaches to:
This must be why Courtesy Nissan only sells the whole gas pedal assembly and not just the pedal for the G sedan.
By taking measurements, the aluminum gas pedal goes a crack over a 1/4" further down than the plastic gas pedal with the stopper. The shape and position of the aluminum pedal is such that it it really doesn't go 1" further than the plastic pedal.
Gas pedal stoppers on older cars typically were used to reduce stretching of the throttle body cable at WOT. Since our cars are drive-by-wire, this doesn't apply. Why would the G sedan has different pedal set-up than all the other FM cars? I guess I'm going to have to devise some sort of stopper (easy to do) because the stopper is clearly there for a reason.
Old Jun 1, 2005 | 12:14 PM
InTgr8r's Avatar
Staff ALUMNI (retired)
Everything G35 lists same kit sedan or coupe.
"Factory Aluminum Pedal Kit (Sedan/Coupe)
440604_21_full
This is the real deal! Factory aluminum pedal kit includes all pieces needed to convert your standard pedals over to the drilled aluminum pedals (dead pedal, e-brake pedal, clip, & bushings are all included)! The e-brake pedal does need to be adhered to the pedal itself, adhesive is not included. A 3M clear adhesive is recommended. ***Price on the 6MT pedal kit reduced!!! All kits are currently in stock.***"
I had no such issues with mine.
Just the pedal changes... not the rod with the stop.
Old Jun 1, 2005 | 12:23 PM
JD_AND_DA_G_RIDE's Avatar
Actually you don't have to buy that plastic stopper, you actually have to cut it to integrate into the aluminum one. My scanner has gone bye bye, otherwise I'd post a pic of what you need to do. I had to do that for the coupe. You may want to search the threads or check on g35frenzy forum and someone is bound to have pics. Hope this helps.
Old Jun 1, 2005 | 12:28 PM
dirrtybear's Avatar
raises all-in
The OEM aluminum pedal kit comes with the gas pedal and stopper.
Look in your box/package. It's sealed separately in its own plastic. I originally thought the stopper was missing too. Good thing I didn't throw away the package.
Old Jun 1, 2005 | 01:35 PM
Sack35's Avatar
Actually, the aluminum kit for the sedan doesn't come with the stopper so you can get the extra power that the coupes have. FREE POWER!
Old Jun 1, 2005 | 05:55 PM
basus's Avatar
I installed alumunium pedals and notice that the gas pedal does not fit tightly as the rest -- when i tap on the top of the gas pedal there is some kind of tapping noise -- is it because its missing a stopper or what
Old Jun 1, 2005 | 08:44 PM
DaveB's Avatar
It's the metal to metal contact of the top of the pedal tapping the metal pedal rod. Wrap a piece of electrical tape around the rod where the pedal contacts and the noise is gone.
Old Jun 1, 2005 | 08:49 PM
DaveB's Avatar
My order from everythingG35 didn't include the stopper and frankly I don't see how a provided stopper would work because the Coupe has the stopper welded on to the rod, not the pedal. You sure you're talking about the same thing as me.
I had no such issues with mine. Just the pedal changes... not the rod with the stop.
There must be difference in the 03 G sedans and the later ones. The stopper is molded into my gas pedal. It's not a welded piece of metal on the rod.
Old Jun 1, 2005 | 10:21 PM
RichK's Avatar
I have the aluminum pedals on my 05 X and have no fitment issues.
Old Jun 1, 2005 | 11:42 PM
DaveB's Avatar
I have no fitment issues either. Everything works fine, but the question here is did your plastic gas pedal have a stopper on it or does the bar that the pedal attaches to have a stopper on it?
Here's what my 03's pedal looks like this:
I remeasured pedal travel and the additional travel the alumninum pedal has over my stock plastic pedal is ~3/16". I'm not going to worry about anything. The car was feeling pretty dang quick at WOT today even though it was muggy and warm
Old Jun 2, 2005 | 06:23 AM
JustBrilliantX's Avatar
Misanthropic nut-cracker
From: On the water at the "Jersey Shore"...Toms River
My pedal bar has the metal stopper. I just ordered the alummies...I'll tell ya what happens
Old Jun 2, 2005 | 10:30 AM
DaveB's Avatar
Then you've got nothing to worry about
I got my pedals on in about 10 minutes. The trick to getting the brake pedal on is using small flathead screw and prying the rubber around base metal pedal. Use a larger flathead screw driver to pop the clip off the plastic gas pedal.
Old Jun 2, 2005 | 02:41 PM
utrain12's Avatar
what is the point of the stopper??
11bEMT
May 27, 2022 03:13 PM
zcherub
Aug 30, 2015 05:04 PM
03sedang35
Aug 29, 2015 07:56 PM
mdzukunft
Drivetrain
Aug 25, 2015 10:28 AM
