G w/ 19s but not lowered?
Old Jun 20, 2005 | 10:07 PM
g35guy86's Avatar
hey when u guys lowered your cars did you do just lowering springs or did u get special struts or shocks? Cause i want to get 18s and i might lower the car if all i need is the lowering springs without damaging my suspension.
Old Jun 20, 2005 | 10:44 PM
SGT's Avatar
SGT
I'm interested in finding out about that too.
Old Jun 20, 2005 | 10:59 PM
Bikecrasher's Avatar
Will the coupes stock 19's fit the sedan if you use 4 of the coupes front rims and tires?
Those look incredible and would make the sedan look bad a.s!!!
Old Jun 21, 2005 | 12:20 AM
V35-6MT's Avatar
this how it looks when dropped on 18's
1.5 all around
ryansg35 I was wondering what your front and rear offsets are?
Old Jun 22, 2005 | 01:24 AM
joes954rr's Avatar
i just used the 350Z springs.
LESSON LEARNED: I actually got the entire suspension package from a 2005 350z, springs, struts, and shock, and originally put them on. BAD IDEA. the struts and shocks are shorter than the G35 (duh...) and they ride rough. I think the struts and shocks just aren't designed for the additional weight, Etc. The car was very stiff. I switched the rear shocks back to the G35 shocks and WOW, big difference. The car rode good, very tight up front and nearly no sway. I though it was a little much. so i switched the struts back to the G35 and that's the combo I liked the most. The car rides better, yet still has improved handling over the G35 stock setup.
My opinion...
Old Jun 22, 2005 | 11:07 PM
amg35's Avatar
Florida G35 Club
My opinion...
Try the 350z springs with a set of Tokico D-spec shocks. This is the setup I am going to use. The reviews of this combo have been fantastic.
Old Jun 24, 2005 | 11:23 AM
darnelled's Avatar
Please list rim size,offset, tire size and any drop amounts that worked for you.
Old Jul 8, 2005 | 06:27 PM
nsanbyker's Avatar
ryansg35, you got pm
KruZZe
Feb 27, 2023 05:04 PM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
g.spot
May 9, 2016 10:54 PM
DRG35R
Jan 31, 2016 07:14 AM
