question on 18" tire size?
Old Jul 20, 2005 | 11:42 PM
DaveB's Avatar
The Tirerack lists height for all their tires. It's quite helpful. And yes, not all tires are created equal when it comes to diameter for a particular size. Like someone pointed out the diameter can be as much as 0.4". That's pretty significant.
Even better about the Tirerack site is they list tire weights. Same size tires can vary in weight by as much as 3lbs. That's significant. Many will be amazed at how much tires weigh too. A set of 225/45R18 weigh around 26-27lbs.
Adding shorter diameter tires will cause the speedo to read high and taller tires will do the opposite. Shorter tires will also change the gearing and your overall torque multiplication. A perfect and extreme example is my 225/50R15 drag radials which are 23.8" in diameter. I've run these tires at the track and the gearing of the car is completely changed. Instead of just tapping the rev limiter in 3rd with the stock 17s just as I pass the 1/4 marker, the DRs force me to shift well over 150' short of the finish line. This hurt my 1/4 times and MPH. I went from 14.4s@98mph on the 17s to 14.5s@96mph. As I passed the finish, the speedo said I was doing 110mph instead of 100mph.
Old Jul 21, 2005 | 10:21 AM
g35guy86's Avatar
so i went to the tire site sumitomotire.com and they had the chart for the tires i wanted HTR Z II and the closest size to match factory is 245/40 if someone could descibe what would would be different on the tire if i compared this tire to a 245/45 tire?
Old Jul 21, 2005 | 10:24 AM
Texasscout's Avatar
A slightly lower profile and less "rolling circumference"
Old Jul 21, 2005 | 10:55 AM
g35guy86's Avatar
alright thanks for the help guys i think im going with 245/40 thats fairly close to the stock 17" tire, but will have a nice low profile to it without looking to small.
Old Jul 21, 2005 | 11:00 AM
GEE35FX's Avatar
Here silver, one of the guys posted this a few days ago. Plug your old size and your new sizes in this calculator below. It will show the general differences.
http://gs.tolan-hoechst.com/tirecalc.htm
Old Jul 21, 2005 | 11:03 AM
g35guy86's Avatar
wow thats deffinitly a handy tool i wish i heard of the site sooner!
Old Jul 21, 2005 | 11:17 AM
KayGee56's Avatar
Originally Posted by Texasscout
as long as you get a tire with the same "rolling circumference", you should be fine. You may see a 1 to 2 mph difference, but not much.
KayGee56, yes it will change your speedo! It's the law of physics, smaller tire turns faster (more turns per mile) for a given road speed (speedo reads fast), larger tire turns slower (fewer turns per mile) for the same road speed (speedo reads slow).
touche
vitamin.v
Nov 7, 2019 06:10 PM
Jnm07
Aug 6, 2015 03:03 AM
reaper76
Aug 5, 2015 10:13 AM
Popes
Jul 29, 2015 05:07 PM
CrazyLogic219
Jul 23, 2015 10:58 AM
