Rev Limiter
Old Jul 27, 2005 | 12:13 AM
agmobb's Avatar
Originally Posted by Mr. G
Some of just like busting people's chops. Anyway, he's a big boy, he sounds like he can take it. BTW, are you a kindergarten teacher?
Not at all. I just think the kind of responses some people have given are better suited for the off topic section where anything goes. How about I just tell him that the best way to warm up his engine is to set it in nuetral, then rev it to 8000 and let it sit there for 20 mins? Tha sounds like some good advice. What if he didnt know any better and tried it because he though this was a helpful board and his engine is toast? Think about these things. I wouldnt wanna ruin somebodys elses car no matter how "dumb" I thought the question was.
BTW GTING...how about a picture of a 2005 G35 6MT at 8000....that should settle it right?
Old Jul 27, 2005 | 12:18 AM
trey.hutcheson's Avatar
Originally Posted by Gting
If you downshift from 4th to 2nd you might be able to hit it before the engine blows. Buddy there is a fuel cut way before 7500rpm and anyone with an 06 6spd who runs their car hard can tell you that. Get some glasses or don't do high rpm down shifts.
Man, are you making an effort to be obnoxious or does it come naturally? I have exceeded 7200 exactly ONCE. I did not intend on doing it. I was not ignorantly endangering my engine. I was not deliberately running it to 8000.
So here's the situation. I can either say, "Ok, you're right, there's a fuel cutoff and I just couldn't tell the difference between 7200 and 7500", or I could go out an actually attempt to exceed 7200 again. But that would just be stupid. So, you can go ahead and continue to be an obnoxious superior know-it-all, or you can just take my word for it. But I assume that the former comes naturally, so it will be the lower effort option. So that leaves me with only one alternative: ignore your posts.
Have a nice day.
Old Jul 27, 2005 | 01:24 AM
Gting's Avatar
This thread sucks too many stupid posts and ignorance. AND NO YOU CANNOT GO PAST A FUEL CUT UNLESS YOU DOWNSHIFT AT A HIGH RPM "FUEL CUT" ie the ecu cuts the fuel so no you cannot go past that rpm!!! And NO the rev light has absolutely nothing to do with the fuel cut/rev limiter.
Old Jul 27, 2005 | 01:37 AM
Andy2434's Avatar
Well, the above is definitely one heck of a way to get your across. LOL
Old Jul 27, 2005 | 02:56 AM
agmobb's Avatar
meh...your car is SLOW
Old Jul 27, 2005 | 03:11 AM
aequitask's Avatar
hahaha this thread is hilarious and has become so pointless at the same time
if i had a manual id go try to do it now...well if it was on lease i mean
Old Jul 27, 2005 | 01:07 PM
bagdan's Avatar
Tested mine yesterday - cut off at 7200 rpm.
Old Jul 27, 2005 | 02:17 PM
Mr. G's Avatar
My font is bigger than yours.
Old Jul 27, 2005 | 06:08 PM
aequitask's Avatar
HAHA
Old Jul 27, 2005 | 06:20 PM
JDM 350GT's Avatar
off topic boys.
who gives damn rather its cut off line is 7200 or 8000
jesus...this is...;
Old Jul 27, 2005 | 06:36 PM
AzSi22's Avatar
If you didn't know, most tachometers are off from what the engine speed is. They can be off by 500-700 RPMs, especially in the upper rev band.
Old Jul 27, 2005 | 06:51 PM
Gting's Avatar
Originally Posted by JDM 350GT
off topic boys.
jesus...this is...;
It does make a difference. Posting incorrect info on forums needs to be corrected. If you had an 05 with 6spd it might make more difference to yourself.
Old Jul 27, 2005 | 06:56 PM
Gting's Avatar
That may be true when connected to an safac or dyno to get the "real" rpm but the tach on an 05 6spd will cut off at 7200 unless a high rpm downshift is made and the engine will probably blow.
Old Jul 27, 2005 | 09:55 PM
shaigh's Avatar
Sorry, I saw 7400-7500 while accelerating in second gear (note: not downshifting)...talking to passengers while showing off...dumb move on my part, but the tach was definitely past 7200. I'm going with the tach being off a little. I believe the rev limiter is at 7200, I just saw higher numbers in the dash.
BTW, why is it called a fuel "cut-off"? It went to the limit and just stayed there (for a sec or so). It didn't even "bounce" like other limiters I've hit (rental cars are fun!). Wouldn't a cut-off kill the engine entirely, lock the tires until the clutch is pushed in, etc.?
Old Aug 2, 2005 | 05:41 PM
  #30
buffjoon87's Avatar
i've definitely gone past 7200 on my 05 6mt tach. i hit the clutch little bit too fast. i guess the tach being off might be a better explaination. i believe it reached close to 8k rpm.
06g35
Feb 14, 2022 05:59 AM
andrewvk
Engine - Complete Motors
32
Apr 7, 2016 01:39 PM
mbe32
Nov 13, 2015 11:09 PM
vamarris
Sep 26, 2015 12:56 PM
