Honestly, whose gone sideways?
Now that the car is finally broken in I love letting the tail hang out on a corner by my house. This is an undeveloped portion of land with nothing obscuring my view around the corner, so no one is in danger. I LOVE the fact that my car handles like this...and it's a sedan! Who else loves a little tailsliding now and again?
I too enjoy a little tail sliding...
How To:
Mine is an automatic (i know i know) so for me, i switch the DVC off, and go to manual mode, in 1st or 2nd, while starting to enter a corner, I wrap up the throttle and give it a good hard turn in, once the RPMs start to go up quickly you know your already sliding, and I turn back out of the turn and hold it til the tires burn off. Normally, I can get a 4-6 second slide and its under full control. Takes a little practice, but once you get the "feel" for the car, you can pick up the speeds and power slide the **** out of the thing.
From my experience and driving style, once the tail stops going out any further, and slowly steer back towards center and the car generally (and I do mena GENERALLY) will return back to straight with only a slight wiggle. Be careful though, if you hold it too long, she will bite back and flip around to the other side... can happen quickly too. Just practive somewhere before you get the bright idea to do this around other people.
Not my recommendation by the way, but if your going to do it, do it with style!
How To:
How To:
How To:
I also have the 5AT. I went into the corner with moderate speed in second, gave her some turn-in and some gas and the tail came right out. Agree, 4 -6 seconds is very easy to obtain. Longer too, if you can laugh your a$s off, whoop, AND steer all at the same time.
I have the base 17" wheels with RS-As and it was scary how easy it was to get the rear end to act silly.
(note to self: remember the last sentence if you get the urge to disable VDC)
