Wheels And Springs
Old Sep 22, 2005 | 05:10 PM
skydiverricardo's Avatar
Wheels And Springs Options. Need your advice please.
Sorry guys I know this topic has been discussed till death. However, I need your comments and feedback. I’m looking to put a set of 19” on my sedan and I set of lowering springs. I’m looking for an aggressive clean look if that makes sense. I want the wheels to look as if they fit perfectly. Don’t want them sticking out too much at all. I hope I make sense here.
I've narrowed down my choices of wheels to the following:
- OZ Superleggera III Light grey w/Polished Lip.
19x8.5 in the front. Off set 33mm. This is the offset Tirerack recommends. The offset sounds a bit off. Any comments??
19x9.5 in the rear. Off set 46mm.
- PIAA Super Rozza Hyper Black: Could not find a correct off set for 19x8.5 and 19x9.5 so I chose
19x8 in the front. Off set 42mm or 35mm. Which one is better??
19x9 in the rear. Off set 45mm.
- SSR GT 10
19x8 in the front. Off set 41mm. This is the offset Tirerack recommends. The offset sounds a bit off. Any comments?? Also, they don’t offer the wheel in 8.5.
19x9.5 in the rear. Off set 55mm. This off set seems quite big. Any comments.
With regards to the springs I’m looking to put Eibachs pro-kit. The reason is the brand name and the life time warranty and no sag.
Guys, I would appreciate all the comments.
Attached Thumbnails Wheels And Springs-oz-wheels-small-.jpg   Wheels And Springs-piaa_superrozza_hb-small-.jpg   Wheels And Springs-ssr-gt-10-small-.jpg
Old Sep 22, 2005 | 05:12 PM
I tried to add the pics of each wheel but don't know how to do it. Any ideas??
Old Sep 22, 2005 | 05:17 PM
Chico's Avatar
It looks like you've done a lot of homework.
Here is my recommendation.
FRONT 19x8.5 +35 to +38 w/ 245/35/19 (+33 will work also)
REAR 19X9.5 +42 to +45 w/ 275/30/19 (+46 will work also)
As for the lowering springs, I also have the Eibach prokit and am very happy with them. The progress rates are as close as you can get to OEM and it makes the car very comfortable to drive it lowered. Can't go wrong!
If you keep your wheels within the above specs you will have a nice flush look.
Good Luck.
Old Sep 22, 2005 | 05:29 PM
Chico,
After reading so many post on wheels and seeing your name I was hoping you would answer. Thank you so much. I definitely will take your reccomendations.
Once I have the set up I'll post the pics.
Is there any rubbing issues with the off sets you are talking about. I want to avoid at all costs any issues and having to roll my fenders.
Old Sep 22, 2005 | 05:30 PM
LuXXXz's Avatar
i like the PIAA rozzas alot how much are they costing you???
Old Sep 22, 2005 | 05:50 PM
smedly's Avatar
I have the Piaa Super Rozza 19" on my car absolutely love them. I went with the hyper black, look sweet on a silver car. I paid $3100.00 I think for the package, went with Continential tires. You won't be dissappointed with these wheels.
Old Sep 22, 2005 | 06:34 PM
Chico's Avatar
Originally Posted by skydiverricardo
Chico,
You will be ok but if you go lower than the Eibach prokit height you may need to roll your fenders a little. BTW, I like all your wheel choices.
Old Sep 22, 2005 | 07:32 PM
LuXXXz's Avatar
how much will the piaa rozzas set me back for 20s staggered???
Old Sep 22, 2005 | 07:34 PM
skeleton_cru's Avatar
Sedan
I think +33 is cutting it VERY close. I would not go smaller than +35mm.
Old Sep 22, 2005 | 07:40 PM
tgenius's Avatar
so between 35 and 40 which would be "better" for a non-staggered setup?
Old Sep 22, 2005 | 08:05 PM
Chico's Avatar
You're right it is not the recommended offset, but the difference between the two is less than 1/8" further out. He will be ok if he likes that wheel he mentioned.
Old Sep 22, 2005 | 08:07 PM
Chico's Avatar
Either one, but I prefer the +35 cause it will be nice and flush with the fender line.
Old Sep 23, 2005 | 04:49 AM
Sedan
A lot depends on his choice in tires as well.
jsimonk
Dec 22, 2023 03:49 PM
Tukeeg35
18 Inch
Aug 25, 2015 06:45 PM
wuppiedog
Aug 7, 2015 11:16 AM
IEMaestro
20 Inch
Jul 30, 2015 04:30 PM
netcbc
Steering & Suspension CDN
Jul 24, 2015 11:25 AM
