Which oil do you use
Old Oct 5, 2005 | 12:50 AM
  #61
Gdup35sedan's Avatar
ENVautoDetailing.com
Originally Posted by t0pher
I have been "advised" by Infiniti service not to switch to Synthetic until after 7500-10000 miles because seals are still seating.
Is there merit to this statement?
and the dealer is......WRONG AGAIN. The piston rings are supposed to seal within the "break-in" period (1200 miles) I changed to mobil 1 full syn. at 2000 miles. The dealer is yankin your chain as they do most people.
Old Oct 5, 2005 | 01:33 AM
  #62
Gordgee's Avatar
Administrator
Actually, there is some evidence to support a longer break-in for the VQ engine. It may be that the seals are already seated, but the VQ engines can continue to show break-in benefits and change up to 15,000 miles on them. There are some posts by Nissan enthusiasts over the years to support this.
Several of the Nissan techs that I know have confirmed this as well, and during at least one of their educational seminars, they were told by the Nissan engineers that going to a full synth isn't recommended until 15K (24K km) to ensure full break-in of the engine.
Of course, you have to decide whom you choose to believe.
To be safe, I decided to wait until I had 12,000 miles on mine before I switched to Mobil 1.
Old Oct 5, 2005 | 02:46 AM
  #63
FrizzleFry's Avatar
Originally Posted by Jeff92se
I'm sure these oils are okay as long as you change it frequently. Don't quote me on this but I believe these two oils tested out to be marginal at best.
i'd really like to know where you read that these were "marginal" oils as Havoline and Chevron are some of the best dino oils out there.
Old Oct 5, 2005 | 03:21 AM
  #64
Jeff92se's Avatar
Red Card Crew
Depending on what weight you use, your two choices seem to have ash contents on the higher side
http://www.atis.net/oil_faq.html
From member test analysis above, Castrol GTX consistently out performed most other dino oils.
Old Oct 5, 2005 | 02:46 PM
  #65
Jeff92se's Avatar
Red Card Crew
My take is why worry about a few thousand miles. Even 10,000 miles is only about 5% of the life of this fine engine? What's the hurry chief? Run a good quality dino like Castrol GTX, change it 3-4000 miles for 10k and then switch.
Old Oct 6, 2005 | 06:30 AM
  #66
socalg35's Avatar
Originally Posted by MrBig
How does that work out for you? Any probs with leaking or anything?
No leaks or anything. Oil drains a little slower because I use the valve with the nipple, but now I don't get oil on my hands and don't worry about the crush washers.
f22raptor
Mar 18, 2016 08:50 AM
prinny
Nov 22, 2015 11:07 PM
mbe32
Nov 13, 2015 11:09 PM
9tray turbo
Sep 29, 2015 10:22 PM
