'05 G35X - 1/4 Times & Questions
Old Oct 21, 2005 | 10:25 AM
trey.hutcheson's Avatar
Originally Posted by LuXXXz
i dont understand how they get these times, i have a 1995 integra gs-r stock i ran it at the track it was like 15.03 in the quarter, the best that i remember and this is from a vtec 170hp 4cyl
now i have a 265hp car and people are saying they're barely braking 15s, what is this people dont know how to drive or is the car really that slow, because it feels alot faster then my integra and its only .4 secs better
Dude, you can't compare that 170 crank hp to the g's 260ish crank hp. It's not all about hp. The g is 3500lbs. What was the integra, somewhere around 2600? That weight just kills you...
And it's also not fair to compare everyone's times... Conditions differ at each event.
Old Oct 21, 2005 | 11:03 AM
ChicagoX's Avatar
Don't drink and Mag Race
Originally Posted by stl_ls1gto
I also say run with the trans in drive, I bet you will be run the same time or better than when you shift it on a stock car.
For bracket racing/consistency I would agree. For lowest times, I would shift in MM mode. For me, it is worth a FULL TENTH in the 1/4 mile.
14.3 shouldn't be too hard. I ran a 14.50 with only a z-tube and a K&N filter. The new mods should put me there.
Old Oct 21, 2005 | 11:36 AM
DP03's Avatar
Interesting. I'll have to try it myself. Every other car I've raced did better letting the computer shift..........
Old Oct 21, 2005 | 12:18 PM
kensandell's Avatar
ChicagoX,
You ran a 14.5 with just a Z-Tube & K&N filter? Did you happen to run your car before the tube/filter? If so, I'm curious to know what you ran before?
I thought my car was supposed to have 10 more HP than 04? Maybe I'm confused?
Anyway -- do you really think the sub and my full-size spare coulda slowed me down that much?
Also, what about getting a 1/4" (5/16" to be exact) plenum spacer -- do you think that actually helps?
Old Oct 21, 2005 | 02:02 PM
DaveB's Avatar
Power to weight my friend. A G35X's performance is really close to that of the GSR. On paper, the X should be about .2-.3 seconds quicker (14.8 vs 15.1), but the trap speeds are about identical (~93-94mph). The G feels a lot faster because there isn't much waiting around for the power.
Other things to consider here are track conditions. I don't know much about Infineon Raceway, but I'd bet it's at a decent elevation. He also didn't state the weather conditions. Elevation and weather conditions (ie density altitude) play a huge roll in the way a car performs. Conditions alone can mean .5 and 3mph difference at the same track.
Old Oct 21, 2005 | 02:05 PM
DaveB's Avatar
I don't know about the G35X, but I do know manually shifting the 2-3 with the RWD G's does improve times and trap speed. If you let the tranny do it's own thing, it will shift the 2-3 at 89mph which is way too early. I hold 3rd through the end and usually tap the limiter (~100mph) 50 feet or so past the finish line.
The X has deeper gearing so a shift into 4th may be required.
Old Oct 21, 2005 | 02:14 PM
DP03's Avatar
You meant the 3-4, right?
Old Oct 21, 2005 | 02:27 PM
kensandell's Avatar
Attached Time Slips below -- My best run had the worst 60' -- my reaction times were terrible. Note the temperature on last / best run.
Attached Thumbnails '05 G35X - 1/4 Times & Questions-timeslips.jpg
Old Oct 21, 2005 | 02:34 PM
DP03's Avatar
Your R/T's were not all that bad (and they don't affect ET @ test & tunes). You do know a perfect R/T is .500, right?
Old Oct 21, 2005 | 02:41 PM
kensandell's Avatar
Actually -- I didn't know a.500 was considered a pefect R/T.
I'll be happy when I get consistant .300 R/T's.
I think that it's very wierd that my best run was with my worst 60'.
That was the only launch of the night that my rear tires spun through first gear.
My AWD Sedan never spins like they did on that launch.
Old Oct 21, 2005 | 03:20 PM
DP03's Avatar
That is odd about your best run being your worst 60'. It usually doesn't work that way. Now, it is very common to get your best trap speed with a lousy, spinning 60'.........
In competition, .500 is a perfect R/T, unless you're running Pro-tree format, in which case it is .400. Anything under .500 or .400 (depending on format) is a red light and disqualification. Some tracks set up their T&T's for a .000 R/T (which could have been the case when you raced), but if you're looking to compete, don't get good at .300's.
Old Oct 21, 2005 | 03:49 PM
kensandell's Avatar
Well, I can't compete, I'm running 14.9's ;-)
Old Oct 22, 2005 | 10:23 AM
ChicagoX's Avatar
You could compete.....the "X" cars make monster bracket racers....just leave in "D" (consistency wins bracket races)
To answer your Q, I was running around a 14.7 before the z-tube + K&N, shifting in MM mode.
The fact that your car did best while spinning tells me that these cars REALLY need a torque converter.
Muski_G
Dec 1, 2023 11:11 AM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
kinetek
Aug 3, 2015 04:25 PM
socalg35x
Jul 28, 2015 10:42 AM
EasySausage
Jul 14, 2015 11:17 PM
