HELP! My 2005 G35x /w 5000km is smoking!
Old Nov 21, 2005 | 06:39 AM
Empz's Avatar
Guys,
I picked up my 2005 G35x over 2 months ago ... I've put about 5,500km on the car since I got it.
I know new cars during the first little while does 'smoke' a little since the welds are new, and there's various 'oils' lingering on the pipes. But for some odd reason even after 5,500km my G still has smoke FLOWING out of the very TOP part of the engine bay after a normal run on the highway. I can't get a good look of what's doing it, since its at the very top.
The smoke isn't rancid as a misused clutch or brake pads after a track day. It just smells a little 'like overheated metal'
Should I be concerned? I've been waiting till I bring it in for my first oil change. Or should I bring it in ASAP?
None of the warning lights have come on.
-E
Old Nov 21, 2005 | 07:06 AM
GEE35FX's Avatar
Something doesn't sound right E. Never had that occur with mine. I think I would be giving the Dealer a call
Wayne
Old Nov 21, 2005 | 07:46 AM
Xman's Avatar
^^^^+1. It doesn't sound right.
Old Nov 21, 2005 | 07:56 AM
RichK's Avatar
Unless you cook food on the engine and forgot to remove it, I'd take it in. I never experienced smoke during the break in.
Old Nov 21, 2005 | 10:29 AM
jawjaw's Avatar
Out of the engine bay? Sounds like something is leaking onto the exhaust manifolds or something. Either way, take it in and get it checked out.
Old Nov 21, 2005 | 01:32 PM
Msedanman's Avatar
O.F. Administrator
Originally Posted by Empz
Guys,
-E
You may have a valve cover leaking which happens now and then. Have the dealer look at it.
C.
Old Nov 21, 2005 | 07:32 PM
Andy77's Avatar
If it smells like metal it could be antifreeze dripping. In any case, let the dealer see it soon, but check your fluids regularly until the dealer sees it. Mine had the engine-protecting-material-burn-off smell for may be 3-5000 miles, more intermittently as time went on.
Old Nov 21, 2005 | 08:51 PM
RLampke's Avatar
Guys,
-E
My car is smoking also - rubber....
Old Nov 22, 2005 | 11:33 AM
JustBrilliantX's Avatar
Misanthropic nut-cracker
From: On the water at the "Jersey Shore"...Toms River
It took me months and many miles to get rid of the oder/smoke generated by the new engine/exhaust protective coatings. That's all it was and probably is in your case too. As I worked for Infiniti at the time, I frequently saw the same happen to many others and was aware of the likelihood it was no biggie. Keep an eye on it, but don't get overly concerned. It seemed to be more prevalent in cars bought in the fall and winter....can't say why however....maybe cooler temps made the 'burn off' take longer???? Good luck, jbx
Old Nov 22, 2005 | 02:39 PM
Empz's Avatar
That's what I thought it was ... that's why I didn't bring my car in right away. It just seems like the burn off is taking longer than I thought.
-E
Old Nov 22, 2005 | 03:58 PM
ekpolk's Avatar
There is one little VQ35 gotcha that might be in play. The wizards who designed the engine placed the oil filler directly above the little opening in the block into which the dipstick threads. In a Maxima (same engine, of course, just sideways...) I saw, there was actually a warning placard under the hood reminding the owner or mech not to add oil unless the dipstick is in place. Oddly enough, no placard in the G that I've seen (not mine, anyway). And I have to admit that I made the mistake once myself -- I added oil, with the stick out, only to have a portion of it gush out the stick opening and drip onto -- you guessed it -- the exhaust. This is merely a possible scenario, plain old cosmoline (the protective grease stuff) burnoff, or something else altogether may be to blame.
One more thing: it's very easy to remove the engine cover, and the engine runs fine without it in place (just a tad noisier without the big plastic "hat" absorbing some engine noise). With the cover off, you'll be able to see what's what much more clearly.
Old Nov 22, 2005 | 07:35 PM
Big difference in the way burning cosmoline and oil smell. You'd know the difference in a heartbeat.....Besides, with only 5,500km on the car he probably hasn't had to add oil ....and he also said it started from the 'git-go'....right?
DANNY_IMPULSE
Oct 25, 2010 10:48 AM
stl_ls1gto
Archived Sales
Jun 3, 2007 02:57 AM
Efiniti
Feb 7, 2006 02:37 PM
kensandell
Oct 22, 2005 10:23 AM
mikeee2
Jan 1, 2005 12:00 AM
