Y Pipe Question
Old Jan 7, 2006 | 10:48 PM
wanalaugh74's Avatar
Y Pipe Question
Is the Coupe Y Pipe the same as the Sedan Y Pipe? Is there a difference in air flow? Thx
Old Jan 8, 2006 | 09:44 AM
SilverII's Avatar
it is the same
Old Jan 8, 2006 | 10:35 AM
boones's Avatar
Same part, also same as 350Z
Old Jan 8, 2006 | 11:05 AM
So there is no benefit to getting a coupe pipe right? Need to go aftermarket?
Old Jan 8, 2006 | 11:30 AM
g35guy86's Avatar
i installed my g with an intense power ypipe with coupe midi and im not sure about alout of gains mybe 5hp but the sound is very nice. Not sure if the ypipe alone does all that much.
Old Jan 8, 2006 | 02:56 PM
boones's Avatar
The improvement would be in the Y-pipe, the coupe midpipe doesn't improve power output, but it's louder (some like that) and 40 lbs or so lighter (that's always good).
Old Jan 8, 2006 | 09:58 PM
jimmyc13's Avatar
Two different things....y-pipe & coupe mid-pipe....just wanted to confirm that you knew that. Judging by your join date on the forum.....do you have an '05? If so, I've heard there's no benefit for upgrading to a coupe mid-pipe...since the '05 sedan midpipe is smaller & lighter than the '03's & '04's..... Let us know what year you have....adding this info. to your signature will help others in future (just a suggestion).
Old Jan 9, 2006 | 12:17 AM
ok my bad.. im am soooo sleepy.. just had twins a month ago and i dunno up from down
I have an 03 sedan with a coupe midpipe already. What i wanted to knwo was about the coupe Y PIPE. Is there a difference from an 04 coupe Y PIPE and a 03 sedan Y PIPE? Basically, should i get it from a buddy or is it a waste of time b/c they are one in the same. thanks
Old Jan 9, 2006 | 01:37 AM
g35guy86's Avatar
they are identical.
Old Jan 9, 2006 | 01:38 PM
jimmyc13's Avatar
Ahhh....very understandable! Yeah...like 03silver said...they're the same. Now if there were a way for you to use his rear exhaust section....that would be a different story.... .
Old Jan 19, 2006 | 05:09 PM
drunkin master's Avatar
I have the sp2. Do the y pipes replace the cats. or do they go behind the cats.
Old Jan 19, 2006 | 05:17 PM
jimmyc13's Avatar
The Y-pipe is the Y-pipe & the cats the cats....if you get along side your car & look underneath just behind the front wheels/axle & you'll the the "Y". The order is: header, cats, y-pipe, midpipe, muffler..........
Old Jan 19, 2006 | 08:03 PM
Cool thx.. nah I don't need the rear part, I got the greddy SP2 from the catback
baker2795
Sep 2, 2015 06:00 PM
Spartan268
Aug 20, 2015 09:14 PM
gatorglaze
Intake & Exhaust
Aug 17, 2015 02:16 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
Black_Out
Intake & Exhaust
16
Aug 1, 2015 08:44 PM
