Dyno 05 5AT w/Stillen exhaust, Crawford cats, and Z-tube
The numbers aren't what I was looking for, but I understand that the car is not fully broken in and plus I have no intake which fudged a little with the overall outcome. Anyway, as you can see my baseline which was done with just the Z-tube laid down 211.27hp/210.43tq and after installing the Stillen exhaust and Crawford high-flow cats I put down 217.21hp/216.90tq. I'm sure the car will lay down a bit more power after the exhaust gets broken in.
Hmmm. How many miles do you have on the car? The 05 is supposed to be 280 at the crank, so with 20% loss on a 5AT, you should have at least 220 RWHP as the baseline. My 03.5 put down 215 HP/TQ bone stock. But I didnt dyno it until it had about 12K miles.
Get your oil changed to M1 5W/30 at 2500 miles or so, then dyno again. I bet the numbers will be higher. It just needs time to loosen up a bit.
You didnt put any big 19-20" wheels on there did you? Also, what was the A/F?
Originally Posted by DaveB
Here is another dyno suggesting that the 260hp 03/04 G35 sedan was indeed making closer to 280hp.
I just don't buy it. The wife's 04.5 5AT's baseline dyno showed 215/208, and my baseline dyno showed 242/212. If her car, at the time of the baseline dynos, was indeed making 280 at the crank, then my car was making about 315 at the crank. Doesn't add up, at least for our two cars.
Originally Posted by trey's wife
Ok you have lost me here???? The car that was dynoed was an '05 so how does that show that the previous models were putting down that power. I'm not seeing your connection there - it's late here so maybe I am just half asleep.
I buy that =)
since i have a 04 lol !! J/K
but well, why dun you wait for your car to have been broken in first!! before you do any dyno? I mean .. give her a few more thousands of miles.. then you can go back to dyno, or maybe even with a tune!!
The 03/04 5AT sedans typically put down 210-215whp stock (Dynojet) which is right in line with what this 05 5AT sedan did stock. Other 5AT 05 sedans have put down similiar numbers. I've witnessed an 03 5AT sedan put down 210whp stock. My point was that the 260hp 03/04 sedans are actually making closer to 270-275hp or close to power of the 280hp 05+ 5AT sedans.
I find it hard to believe that they would have a 25% powertrain loss with the automatic transmission. I would say it MORE likely that the 05 autos are being inflated to some degree. Also, I will say that dyno conditions make a lot of difference in results. There are SOOOOOO many factors there that I am not fond of comparing dynos that weren't done the same day and the same place. Just my .02 on your thoughts. As in most things - to each his own.
Originally Posted by absolutg
wow, those numbers after the stillen exhaust and cats are really surprisingly low! 6hp/ftlb is shockingly low...
Originally Posted by Mario77746
Why does everyone assume bigger wheels will result in lower numbers? Our 18's use a larger profile tire than a 19 would. Put them size by size with a 18 - 245 tire and a 19 - 235 tire, they will be very close if not similar.
Also, just because a tire is lower in profile, doesn't mean it's lighter. Low profile tires are heavy because they have thick rubber and reinforced sidewalls and multiple belts for high speed. Lots of dense rubber equals a heavy tire.
