View Poll Results: What is the Best Setting for Stillen Sway Bars?
Front-Soft/Rear-Medium
12
26.09%
Front-Medium/Rear-Medium
18
39.13%
Front-Medium/Rear-High
17.39%
Other - Please Post Reply
17.39%
Voters: 46. You may not vote on this poll
Stillen Sway Setting for Sedan??
Old Mar 13, 2006 | 12:46 PM
g35guy86's Avatar
Question
I asked this in another thread but what would be the best setting for a G sedan with 05 350z struts and 03 350z springs? anyone have this setup and also have the stillen sways?
Old Mar 13, 2006 | 06:07 PM
jimmykce1's Avatar
I have some people tell me that soft-front and high - rear for models with OEM Sport suspension. Also this setting would eliminate understeer.
Old Mar 13, 2006 | 06:19 PM
ttrank's Avatar
Grocery getter
I just got my Stillen sways on and they are med/med but so far I don't like it. I think I'm going to try Soft/Med.
Old Mar 13, 2006 | 08:14 PM
jeffy1's Avatar
ttrank, what don't you like about the med/med setting?
Old Mar 13, 2006 | 08:23 PM
vodkarocket's Avatar
Modded Member
This is horrible advice. This can lead to snap-oversteer and unpredictable at-limit behavior, and isn't the safest or most practical setting to use. Soft F/medium R is an excellent starting point, and if you feel like you want to make the car a bit more neutral medium F/medium R is a great step.
Your '06 sports springs are the same as other OEM sport setups.
Old Mar 13, 2006 | 10:37 PM
g35guy86's Avatar
so would you say the 350z suspension is pretty close to sport sedan suspension? because im going from a nonsport suspension to z suspension so i wasnt sure how the ride is with sport verses 350z.
Old Mar 14, 2006 | 12:03 AM
trebien's Avatar
I was about to post up in agreement.
Soft front and hard rear would get pretty twitchy. Not to mention in the rain.
I have the OEM sport suspension, and med/med seems to give excellent balance/neutrality around corners...
Remember - most aftermarket sways (including Stillen) are already setup to be stiffer in the rear than oem, compared to the front. So a med/med setting still stiffens up the rear more than it does the front (comparatively).
In other words, a med/med setting reduces the understeer considerably, even though both bars are on the "same" setting (med).
Old Mar 14, 2006 | 06:53 AM
jimmykce1's Avatar
Thanks for the advice. I will use med-front & rear. Would I need an alignment after the sways are installed??
Old Mar 14, 2006 | 09:36 AM
cato's Avatar
SouthernComfort Moderator
I have had soft/front hard/rear sut up for close to 2 years now. Never once has the rear end swung out. Its very balanced thru the turns.
rezendvous420
May 31, 2020 01:26 PM
laksjd84
Steering & Suspension
16
Jul 12, 2017 12:22 AM
itschuckster
Jul 25, 2015 08:07 AM
wylin
Lights
Jul 18, 2015 06:12 PM
mushu
Jul 15, 2015 03:55 PM
