Stillen Sway Setting for Sedan??
View Poll Results: What is the Best Setting for Stillen Sway Bars?
Front-Soft/Rear-Medium
12
26.09%
Front-Medium/Rear-Medium
18
39.13%
Front-Medium/Rear-High
17.39%
Other - Please Post Reply
17.39%
Voters: 46. You may not vote on this poll
Mar 6, 2006 | 06:35 AM
Would like to know whats the best setting for the Stillen Sway bars on a sports-tune sedan??
Reply 0
Mar 6, 2006 | 07:38 AM
Best setting is subjective..... I first set both front and rear at the firmest setting, hole closest to the bar. No body roll whatsoever. After reading Q45tech's comments about sway bars, I moved the front bar to the lightest setting, hole furthest away from the bar. No Understeer any more! You will probably want to experiment with various setting.
Reply 0
Mar 6, 2006 | 12:23 PM
Quote: Best setting is subjective..... I first set both front and rear at the firmest setting, hole closest to the bar. No body roll whatsoever. After reading Q45tech's comments about sway bars, I moved the front bar to the lightest setting, hole furthest away from the bar. No Understeer any more! You will probably want to experiment with various setting.
So you are running front-soft and rear-high. How long have you been running this setting?
Reply 0
Mar 6, 2006 | 01:58 PM
Quote: So you are running front-soft and rear-high. How long have you been running this setting?
About a year and a half.
Reply 0
Mar 6, 2006 | 02:14 PM
Great post jimmy I am interested in the same feedback along with how long have users been running with this setup.
Reply 0
Mar 6, 2006 | 02:30 PM
Quote: Great post jimmy I am interested in the same feedback along with how long have users been running with this setup.
Thanks!!
So far it seems people are running med - front and rear.
Reply 0
Mar 6, 2006 | 03:47 PM
I wouldn't say that there is a "best setting" but I honestly think that you have to play around with it and see what feels good to you because we all drive differently. Med/Med is a starting point... then just play around. Adjusting and going to test them will be time consuming but well worth it since we do have the adjustability available to us.
I have mine at med/med on my coupe but if I was running different springs, shocks, wheels and tires I may have gone with different settings.
Reply 0
Mar 6, 2006 | 04:36 PM
^ As Chris said, it really relies on how your suspension mods compliment one another, and your driving style. I'm running staggered 19's, Tein coilovers, and my Stillen sways were set at Soft F/Medium R. However, I'm going to set them to Medium/Medium the next time I have a chance to get under my car.
Reply 0
Mar 6, 2006 | 06:43 PM
I will currently be running the OEM sport suspension for now.
Reply 0
Mar 7, 2006 | 06:09 AM
bump
Reply 0
Mar 7, 2006 | 01:59 PM
Like everyone said, adjustable sway bars are meant as a tool to fine tune your suspension according to YOUR driving style and goals. With that said start off on med/med since your running the OEM sport suspension. Then experiment if you wish.
Reply 0
Mar 7, 2006 | 11:00 PM
I just had mine installed today, front soft, rear stiff. Will keep you posted on my opinion. Currently running OEM shocks.
Reply 0
Mar 8, 2006 | 07:58 AM
Quote: I just had mine installed today, front soft, rear stiff. Will keep you posted on my opinion. Currently running OEM shocks.
Good choice! No more understeer.
Reply 0
Mar 10, 2006 | 08:00 PM
Someone said that the 06 springs are stiffer and that he wold rcommend not going past mediums. What settings are you using on 06 models??
Reply 0
Mar 10, 2006 | 11:41 PM
G Sedans understeer pretty badly (supposedly for safety purposes), so it's crazy not to try to offset this with your swaybar settings. Definitely go firmer in the rear than the front.
-T
Reply 0
