Will these rims fit?
Mar 14, 2006 | 09:00 PM
I have an 05 G35X. Will the size fit
19 x 8.5 front 20mm
19 x 9.5 rear 30mm
Any info will we great.
Reply 0
Mar 14, 2006 | 09:45 PM
depends on the offset. You will need +35 minimum, I think. Anyone?
Reply 0
Mar 14, 2006 | 09:48 PM
35+ front
40+ rear
Reply 0
Mar 14, 2006 | 09:50 PM
No! See my reply in the other thread you started.
Reply 0
Quote: 35+ front
40+ rear
+40 rear is not enough. Ideal offsets would be +43 --> +45 for the rear.
Reply 0
Mar 14, 2006 | 09:56 PM
Quote: +40 rear is not enough. Ideal offsets would be +43 --> +45 for the rear.
Is that b/c it is an X? (my bad)
b/c 35+ front and 40+ rear is ideal for RWD sedan.
Reply 0
Mar 14, 2006 | 10:03 PM
The X should not run stagger in the first place (I posted this in the other thread seddon made); it will affect the traction control system and his AWD system.
If the car was in fact RWD, +40 for a 9.5" wheel will fit, but it will also require fender rolling and/or running some negative camber to avoid rubbing if he lowers his car. He is much safer getting +43 --> +45...
Reply 0
Mar 14, 2006 | 11:59 PM
reymcruz2003 see your other thread. +35 will rub.
Reply 0
Mar 15, 2006 | 12:01 AM
Quote: The X should not run stagger in the first place (I posted this in the other thread seddon made); it will affect the traction control system and his AWD system.
this conflicts with what many have said to me on RWD that 19 X 9.5 +40 with a 275 tire will fit perfect with NO fender rolling and can be lowered 1 inch with no rubbing problems.
You can see PDT and G35keg here https://g35driver.com/forums/showthr...47#post1032147
PDT has that exact set up 9.5 +40 275 1" drop and no rub and no rolled lip
G35keg has 9.5 34+ 255 narrower tire and 1.1" tire, no rub and no roll
thats 2 of many examples on this board and 2 wheel shops that have concurred.
Reply 0
Mar 15, 2006 | 12:05 AM
Quote: reymcruz2003 see your other thread. +35 will rub.
Not true +35 is a common size here on the board not to mention I am running +35 no rubbing and they don't stick out to far it's even with the fenders even if you lower you won't have a problem. I have eibachs.
Reply 0
Mar 15, 2006 | 12:13 AM
Quote: Not true +35 is a common size here on the board not to mention I am running +35 no rubbing and they don't stick out to far it's even with the fenders even if you lower you won't have a problem. I have eibachs.
then why is vodka saying +40 is "not-safe"
Reply 0
Mar 15, 2006 | 01:13 AM
Don't listen to codeflux...the set you you chose is perfect and won't have any problems at all. I guatantee it.
codeflux, get your facts straight and stop misleading and confusing people with wrong fitment info.
Reply 0
Mar 15, 2006 | 01:14 AM
Quote: then why is vodka saying +40 is "not-safe"
vodka was referring to a +40 offset on a 9.5" rim. He's asking about an 8.5" rim with a +35 offset.
Reply 0
Mar 15, 2006 | 02:05 AM
Quote: vodka was referring to a +40 offset on a 9.5" rim. He's asking about an 8.5" rim with a +35 offset.
thats my point whats wrong with a 40+ on a 19 x 9.5" rim
Reply 0
Mar 15, 2006 | 02:18 AM
Quote: thats my point whats wrong with a 40+ on a 19 x 9.5" rim
a 9.5" wheel on a 275 series tire in the rear will look like a race car you can do it but it just wouldn't look right. I hope we cleared up the whole 8.5 inch wheel with a +35 offset
Reply 0
