Rims for 05X
Old Mar 18, 2006 | 04:48 PM
apintojr's Avatar
Rims for 05X
wondering wich set will fit my car. i want the same size wheel on the way around.
19x8.0 Volk Racing GT-V 5x114.3
19x8.0 Volk Racing GT-V 5x100
19x8.5 Volk Racing GT-V 5x114.3
Old Mar 18, 2006 | 06:02 PM
Xman's Avatar
Your bolt pattern is 5x114 so that eliminates one. What are the offsets?
Old Mar 18, 2006 | 09:18 PM
stl_ls1gto's Avatar
I would think that the 8.5 in wide width would be a little too wide....I would stick with the 8 inchers, that is still an inch wider than stock. I mean the 8.5 in width ususally uses 265-275 tires - you wont have those all the way around on a g35. The 8 in width, with maybe a 235-245 would be a nice improvment over the stock 225's.
Old Mar 20, 2006 | 09:17 AM
apintojr's Avatar
19x8.0 Volk Racing GT-V 5x114.3 +40 offset. we this fit fine on my 05x
Old Mar 20, 2006 | 09:36 AM
RichK's Avatar
Yep.
Old Mar 20, 2006 | 10:31 AM
apintojr's Avatar
as far as tires whats the better fit. 235/35/19 or 235/40/19
245/35/19 or 245/40/19
with a offset of +40
Old Mar 20, 2006 | 12:59 PM
Gdup35sedan's Avatar
ENVautoDetailing.com
what are you smokin? You dont run 265's on an 8.5 wide wheel. The norm around here with G's is 245 front and 275 rear on a staggered set-up but he cant get staggered because of the AWD so 8.5 all around would be perfect with a 245/35 tire.
-GP-
Old Mar 20, 2006 | 02:03 PM
apintojr's Avatar
19x8.5 Volk Racing GT-V 5x114.3 +35 offset. 245/35/19
19x8 Volk Racing GT-V 5x114.3 +40 offset. 235/35/19
whats the better setup. i am on planning on dropping the ride only about a inch or inch/half.
Old Mar 20, 2006 | 02:08 PM
The first option would be the best imo. the rims will be flush with the the fender and if you drop it an inch it would look percect.
-GP-
Old Mar 20, 2006 | 04:20 PM
apintojr's Avatar
thanx for the help. i'll go check out the wheels this weekend. i guess i'll go with the 19X8.5 245/35/19 +35 offset.
Old Mar 20, 2006 | 11:27 PM
stl_ls1gto's Avatar
-GP-
why not? cars with 245's come with an 8 in wide rim such as my GTO(17x8 stock). Move up to an 8.5 in rim, you can run a little more width such as 255-275.
I actually have some Nitto drags in a size 275 on a set of stock 8 in rims, and they work perfect on my goat - they are the widest tire you can put on the GTO without rolling the fenders. This is because the Nitto's run narrow though. I wouldn't put any other tire in a 275 on a stock GTO as it would rub.
Old Mar 20, 2006 | 11:32 PM
never said they dont work on goat's, but for the G35's you dont run 275's on an 8-8.5 wide wheel. plus on the GTO or mustangs you're only using 275's for drag racing, if you put 275's on an 8.5" wheel on a car like the G while you're carving through the canyon... say bye bye to all stability of that tire.
-GP-
Old Mar 21, 2006 | 01:25 AM
Machine Head's Avatar
I'm running 19X8.5 on a 42 mm offset and they sit perfect
Old Mar 21, 2006 | 06:18 AM
skeleton_cru's Avatar
Sedan
If you could get 19x8.5, +40 offset, that would be ideal, but +35 works.
Old Mar 21, 2006 | 06:19 AM
Sedan
Stop thinking Pontiac and start thinking Infiniti.
