What's the difference? I just bought my sedan this month, and checked the build date. It was built in Nov '02. That's 9 months old. I just wanted to know if they have improved anything since then? Thanks
Nov. '02 was after the 03/03.5 switchover.
There are a ton of posts on this topic, if you run a search you can find most of them, but I'll recap for you:
1) Moved the memory seat buttons
2) Changed the trunk (No longer has handle/boxy thing) and added internal trunk release
3) Softened up the brakes a smidge
4) Added an extra power outlet
5) New seat aesthetic design (Infiniti logo embroidered)
That's all you're really notice... I'm sure there are some other little bonuses we can't see. Hope this helps,
G
4) Did some interior styling a little differntly
2003.5 Black w/ Willow G35
Premium / Sport / Aero / Winter / Navi / Tint
G
I appreciate the help, but nismo, what exactly do you suggest to type in for that search? I typed in a few different things, but came up with nothing. No need to be an ***. I didn't mean to take up precious forum space. I didn't force you to reply.
the point is that there is a search function and there are lots of new members coming all the time, and it gets a little annoying for everyone when the same questions are asked over and over. Before I post I search to see If I can find my answer if I need more detail I will make a post. This particular subject was covered extensively just last week though. Welcome to the board.
https://g35driver.com/forums/showfla...sed&sb=5&part=
Back in Black
Back in Black
Well, thing is, I did do a search and found nothing. Maybe I didn't type in the perfect combination, but I tried a few things. Trust me, I know about the newbie thing. I have been part of SVTperformance forum for quite some time now, and I know how repetitive certain questions can be. Besides, your title is still a newbie. Seems to me that you should have a few more posts under your belt before you start acting like the originator of g35driver.
khsonic-
I found some results with "difference 03.5 03" with 'AND' in the search function. The key is the drop-down box for boolean searching... didn't know if you'd seen it. Best of luck,
G
G
Ah, I see. This forum is a different format than the Bulletin versions. Thank you sir.
No problem buddy.
G
G
