conflicting info - 20x8.5 with +?offset
Old Apr 6, 2006 | 01:28 AM
Gdup35sedan's Avatar
ENVautoDetailing.com
i believe you, but it just seems like they would stick out alot more than it looks like in your pic.
-GP-
Old Apr 6, 2006 | 01:46 AM
vodkarocket's Avatar
Modded Member
It's absolutely a mistake. +30 would be inline with the fender. +20 would as Grant says stick out over an inch...
EDIT: Just did some research on these. It seems like standard offsets for 19x8.5" or 20x8.5" wheels is +40. That is exactly what it looks like as they are mounted on your car too. There must have been a mistake made by your distributor...
Old Apr 7, 2006 | 11:28 AM
skeleton_cru's Avatar
Sedan
Originally Posted by ttrank
We are going to try to see if a 20x10 +43 with a 275/30/20 555 will fit in the rear on Friday.
You'll need a bigger offset, I'm guessing. More like +50/+55.
Old Apr 7, 2006 | 11:32 AM
Modded Member
I really doubt that a +55 on a 10" wheel would fit. I think that would rub against the inner fender and suspension...
Old Apr 7, 2006 | 12:47 PM
Sedan
I dunno, check it out...
Attached Thumbnails conflicting info - 20x8.5 with +?offset-sedan_wheel_fitment_chart.jpg
Old Apr 7, 2006 | 12:55 PM
Modded Member
Looks like if there is any negative camber, you are fvcked.
Old Apr 7, 2006 | 01:04 PM
Sedan
Plus the tires. That chart is just for the wheel, it doesn't take into account tires. You'd probably have to use narrow tires so the rounded edges don't rub.
When I had my wheels mounted, the guy at the shop said "You have a lot more room in the rear" as if my 8.5's weren't wide enough. LOL.
Old Apr 7, 2006 | 01:28 PM
ttrank's Avatar
Grocery getter
I don't think that chart is right when it comes to the inside limit. We tried the 20x10 +43 with a 285/30/20 Pilot Sport yesterday and my car was too low. It just barely hit the outer quarter panel and had room on the inside. My car just tucks the tires all the way around. I rolled my fenders last night and we are going to try a 275/30 today. It is very close.
Old Apr 7, 2006 | 05:40 PM
Sedan
So a bigger offset would keep it from rubbing the fender, right?
Old Apr 8, 2006 | 02:55 AM
ttrank's Avatar
Grocery getter
They fit!!!!
I rolled my fenders and they just clear; even with the H&R drop. There is no rubbing at all. I have like 5mm between the tire and fender.
I will post some pics soon.
Yes as the offset gets larger the less chance of rubbing on the fender. I checked my 8.5's and they don't say what the offest is on them.
Old Apr 8, 2006 | 03:03 PM
da mayor's Avatar
rims usually don't say what the offset is unless it is a OEM wheel.
Old Apr 8, 2006 | 04:45 PM
az1anbeethoven's Avatar
most aftermarket rims actually do give you the offset on the back of the rim on the spokes
Old May 2, 2006 | 02:58 AM
MidnightClayton's Avatar
Originally Posted by tkman00
you'll probably want to lower after them anyway
Originally Posted by rltaylor
I've got 20 x 8.5 with +35 offset and same tires. I have no rubbing issues and the Eibach Pro kit goes on next week. It still needs the drop. Trust me, the gap will bug you.
You guys were RIGHT, the gap does bug me and I want to lower it. I finally got my wheels last week.
The Eibach kit is on now and no rubbing issues. Once again, I have 20 x 8.5's with +35mm offset. No rub, and no gap. Luv'n it....
RT
rltaylor... question? now that your eibach kit has settled, how do u like it? Any issues? How much did it drop?
Old May 2, 2006 | 08:37 AM
Esoteric's Avatar
So your car is not lowered in the 'show me your wheels' thread? Wow, i could have sword it was lowered.
I have the same wheels ready to be mounted, but was waiting to put on my z springs.
I thought it looked great in those pictures.
I guess I'll found out how it'll look lowered this weekend when I get mine mounted
Picture Share
Feb 4, 2018 12:41 PM
The Fixer
Steering & Suspension
Nov 1, 2015 03:26 PM
Rose M
Oct 12, 2015 10:00 AM
TurTLe*
Sep 29, 2015 01:43 PM
